shift linkage removal
Old Apr 24, 2004 | 07:38 PM
Royalty's Avatar
Default shift linkage removal
Ok call me a dumbass, but i cannot for the life of me remove my shift linkage
can one of your l33t rex drivers give me some help here please?
oh yea i forgot
89 CRX SI
Old Apr 24, 2004 | 08:12 PM
tpr's Avatar
tpr
Default Re: shift linkage removal (Royalty)
Which end? Transmsiison or at the shifter on the body of the car? At the Transmission end remove the 12 mm (head) bolt from the stabizer bar???? then shift the transmission into a gear 1st,3rd,or 5th (having the smallest amount of shifter shaft coming out of the transmission as practical) drive the roll pin out. This pin is under a collar under the rubber boot (if it, the boot, is still intact). I use the proper sized pin punch but have seen references to using the appropriate sized bolt to drive the pin out (up is easiest). Remember, however that this is the shaft that shifts the transmsiion so be frim but not stupid when hitting the pin.
The body end is much easier as two bolts (10-12??? mm head) into the shifter and two in the shifter stabliazer that hold most everly thing up. I would have to consult my Helms manual to be sure. Just look up under there and it should be apparent.
Old Apr 24, 2004 | 08:26 PM
Royalty's Avatar
Default Re: shift linkage removal (tpr)
THANK YOU SIR WORKED LIKE A CHARM
SlowPokeEg
Aug 21, 2011 10:00 AM
88EFhatch
14
Jun 8, 2005 06:11 PM
crxzcracer
10
Jun 20, 2004 09:54 PM
made in JAPAN
Jan 31, 2003 08:22 PM
92CIVICCX
Jan 20, 2003 11:10 AM
