Help need fuel advice???
Old Apr 24, 2004 | 06:37 PM
MysteryWagon's Avatar
Default Help need fuel advice???
I have a 8.5 compression Lsvtec
-milled B16 head .24
-stock injectors and fuel pump
-turbo has been placed on hold do to financial problems, but I still need a daily driver.
? is what is a good fuel pressure for that low of compression?
-symptoms, it is at 45psi right know with a civic pump, car chokes on fuel when turned on and at full throttle car back fires so much that it hesitates, only readings I have are from the A/f guage and it is rich when gas is mashed
-timming about 17 degrees
thanks If I can geet it running right car feels like at least Monday B16 power
thanks Justin
Old Apr 24, 2004 | 08:01 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Help need fuel advice??? (MysteryWagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MysteryWagon &raquo;</TD></TR><TR><TD CLASS="quote">I have a 8.5 compression Lsvtec
thanks Justin</TD></TR></TABLE>
Put the PSI at 40 psi and tune it from there. I only trust wideband A/F mixture gauges. Regular A/F mixture gauges like Autometers only know rich or lean, they aren't exact.
Blacklabel182
Mar 29, 2007 11:37 AM
Ruben19
Mar 10, 2006 03:23 AM
tt281gt
Mar 17, 2004 04:22 PM
phantom_sol
Jan 22, 2004 11:50 PM
