JIC Suspension Adjustable Height Question
Old Apr 24, 2004 | 04:21 PM
TurboTeG4's Avatar
Default JIC Suspension Adjustable Height Question
To raise the car with the Jic Suspension on a teg you would tighten the fittings so it would squeeze the spring correct? The fitting that is the lowest, is that adjustable or is it just a lock?
Old Apr 24, 2004 | 06:23 PM
deepgreengsr's Avatar
Default Re: JIC Suspension Adjustable Height Question (TurboTeG4)
its adjustable without squeezing the spring. the lower lock loosens and the perch rises and lowers, its threaded. you can adjust the front easilly and the rears are a little harder. but in no way are they all too hard to do. you should never have to adjust the pre tension.
MR_Ek4
Suspension & Brakes
Sep 8, 2006 03:34 PM
beefjerky
Oct 10, 2005 09:30 PM
- Sim -
Dec 27, 2004 06:35 AM
itr1236
Mar 6, 2003 09:13 PM
