fly cutting a head...
Old Apr 24, 2004 | 04:11 PM
H22CL's Avatar
Default fly cutting a head...
what exactly does this consist of and what are the benefits? thanks
Old Apr 24, 2004 | 06:25 PM
deepgreengsr's Avatar
Default Re: fly cutting a head... (H22CL)
makes the combustion chamber smaller, ie Higher compression. The drawbacks are the cams are retarded cus the head is shorter. nothing adj cam gears wont fix. and some people have head warpage problems when they deck too much off.
Old Apr 24, 2004 | 07:41 PM
Chiovnidca's Avatar
Default Re: fly cutting a head... (deepgreengsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deepgreengsr &raquo;</TD></TR><TR><TD CLASS="quote">makes the combustion chamber smaller, ie Higher compression. The drawbacks are the cams are retarded cus the head is shorter. nothing adj cam gears wont fix. and some people have head warpage problems when they deck too much off.</TD></TR></TABLE>
I've never heard flycutting to describe milling a head. I've heard of flycutting pistons to to make clearance for valves.
Old Apr 24, 2004 | 08:39 PM
StyleTEG's Avatar
Milling also reduces quench area.
Old Apr 24, 2004 | 08:53 PM
func-tion's Avatar
Default Re: fly cutting a head... (Chiovnidca)
A fly cutter is a fancy drill bit that is used in a mill thats all. They are used to cut wide surfaces in small incriments.
Here is a link for a small one.
http://homepage3.nifty.com/ami...e.htm
The ones that should be used to mill a head should be atleast as wide as the head so it wont have the risk of leaving a step if the mill is slightly out of tram.
Old Apr 24, 2004 | 09:31 PM
Chiovnidca's Avatar
Default Re: fly cutting a head... (func-tion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by func-tion &raquo;</TD></TR><TR><TD CLASS="quote">A fly cutter is a fancy drill bit that is used in a mill thats all. They are used to cut wide surfaces in small incriments.
ah, I see. thankyou
the.hamburglar
11
Jun 28, 2006 02:10 PM
rice is nice
May 21, 2005 11:52 AM
KOREAN
14
Apr 5, 2005 04:49 PM
WAFFLES
11
Jan 3, 2004 12:32 AM
KRiS1
Aug 26, 2003 08:58 PM
