Brake Stumper ?
Hey everyone wussup again ? I was wondering something real quick and simple. I found at a local junk a 90' acura integra "RS" 4 dr with of course front and rear disc. I know that ls front and rear fit and that the aligment goes of a bit xcetera. I have done alot of research on the topic so don't tell me to search, lol. If you want I'll post all the threads I have on my fav. about the subject. I couldn't find any mentioning 4 dr teg "RS" front or rear brakes ? I wanted to know b/c I plan on doing the swap to bigger brakes and since I know the people at the junk I can get it pretty much for nothing. I figure they are the same as the ls/gsr ones. I getting everything the 4040 valve xcetera.
Basically, the question is -> Do 90' "RS" 4 dr integra front and rear brakes swap over to my 91 civic hatch ? You know the arm and spindle xcetera ?
Good Day,
sohc hatch
Good Day,
sohc hatch
the 4dr **** works fine...i have it on my hatch. there were no differences in the 4dr front suspension compared to the 3dr. the rear suspension is the same, the trailing arm mounts in the same spot on the car. the only difference is the wheel base is longer.
Thanks or the reply. I plan on getting the front's tomorrow and the backs later. If they get sold I can always find another pair. My main concern was the front bolting on it bieng from a 4 dr. Thanks again - I really appriaciate it.
Good Day,
sohc hatch
PS. On another note by the wheel base bieng longer did you run into any problems ? I like your personal opinion if possible since it is coming from experiences and not just word of mouth ? Does it ride nicely ? You like your overall handling and braking ?
Good Day,
sohc hatch
Don't use integra compensator arms!!!! They're longer and will make your rear tires toe in.
Everything else from the DA will bolt right up. Good luck.
qat727
Dec 14, 2006 07:59 PM
