chassis vibrating on corning... LEFT and RIGHT (88 civic standard)
my suspension setup
skunk2 coilovers (integra rates)
kyb gr2's
ballon tires! 185/60/14
it vibrates more so turning hard right then left, at first i thought it was my crappy 185/60/14 inch tires but i put my friends rims with azeni sport tires on and it did it even worse..... the sound is similar to when you Roll your R's when you speak like RRRRRRRR (anyone that has an asian mom will know what im talking about my mom does it all the time too) and the vibration is as if someone was running a small air chisel or similar in the car..... any idea, my thought is maybe worn bushings? TIA
kyb gr2's
I had that happen with my GSR a few years ago when I had a set of Driveshaft Shop axles in the car. Significant vibration at speed, enough to drop 5-6 mph off my speed on the back straight at Watkins Glen. On my car I only had the sound on left hand turns with heavy loading. I sounded like going across washboard pavement. That was the only change from the last time I had been there. I took them out and replaced them with a generic auto parts store one on the driver's side and a factory one with new boots on the passenger side. No more vibration or sound! The mismatched axles were due to the driver's side one being toast and the other just having bad boots.
hrm sounds like my problem! i just replaced the drivers side with a 90 - 93 teg axle, i think its time to replace the pass side ( i have a swap )
THANKS for the help!
any more comment or help will be apperciated
The theory for the problem with the Driveshaft Shop axles was the shaft was too long and they had binding issues where the inner joint got bottomed out. It needs to be able to slide in and out as the suspension moves. Your problem could be either the new axle is too long or the old one is dying.
ya thats what i think it is, cuz when my car dips ( like on consecutive hills and such a sort, big dips at higher speeds ) it also does this
Hey importboi22,
I am interested in the Coilovers you are selling in the Classifieds, but I cant Post in there. I want them. Please Email me at: stupac30@hotmail.com
Thanks!
Thanks!
fromthesun_93
13
Sep 12, 2011 08:56 PM
importdreamer
10
Oct 23, 2007 05:19 PM
importboi22
10
Apr 26, 2004 06:04 AM
