adding a relay, wiring help please.
Old Apr 24, 2004 | 02:53 PM
crxgator's Avatar
Default adding a relay, wiring help please.
I have a bosch single pole relay and i need it to install my foglights legally so that they turn off when i put the high beams on...so basically i need help to decide which wire goes to where...thanks
30-blue
85-white
86-black
87-yellow
87a-red
im taking a guess, but i think 86/black would be body ground, and red would be power to the battery...any help is appreciated...
Old Apr 25, 2004 | 08:26 AM
Wes V's Avatar
Default Re: adding a relay, wiring help please. (crxgator)
I'd recommend that you go to "the12volt.com" for any information that you may want on relays. If you look over their site, you will find the answer and also a whole bunch of other ideas.
Wes
Old Apr 25, 2004 | 10:07 AM
crxgator's Avatar
Default Re: adding a relay, wiring help please. (Wes V)
so:
30/blue=power from foglight switch
85/white=power from battery
86/black= ground to body
87/yellow=foglight power
87a/red= high beam power wire
is that correct?
ESP.net
Engine Management and Tuning
Mar 10, 2014 05:58 AM
pnwjdm
17
Sep 29, 2013 01:11 PM
j4s0n1337
May 6, 2011 12:00 PM
importdude2000
Audio / Security / Video
Aug 8, 2007 03:31 PM
ILLICON3000
Dec 13, 2004 07:15 AM
