which ITB's are plug and play??
Old Apr 24, 2004 | 02:13 PM
DSRxSALSA's Avatar
Default which ITB's are plug and play??
any other set of itb's for a home made set up plug and play or with little wiring besides the CBR 954's. i want something a little bigger such as the gsx'r 1000 itbs. searched but i didnt get the asnwer to my question. thanx any information would be useful
Old Apr 24, 2004 | 02:50 PM
Kendall's Avatar
The CBR 954RR's are the same size as the GSXR 1000's and are pretty much plug and play. Good luck finding a set though.
Old Apr 24, 2004 | 02:52 PM
DSRxSALSA's Avatar
oh i didnt know they were the same size. yeah thats what im worried about the problem about finding a set. what about the GSXR 1000's is there much wiring w/ those besides the TPS
Old Apr 24, 2004 | 02:57 PM
Kendall's Avatar
There is abolutely no wiring at all when dealing with the GSXR 1000 setup. All you have to do is mount the Honda TPS and then everything is plug and play.
Old Apr 24, 2004 | 04:40 PM
dfoxengr's Avatar
Default Re: (Kendall)
1000's are apparently the best. search a bit, theres a few really awesome threads on this
Old Apr 24, 2004 | 05:01 PM
DSRxSALSA's Avatar
will search. but just wanted to know quickly if there a lot of wire chopping involved?
Old Apr 24, 2004 | 05:13 PM
RenoRacing's Avatar
Default Re: (92integGS)
cbr 929 and 954 are all plug and play down to the map, tps, injectors swap out, fpr's and rails are the same fittings. the throttle cable even fits without too much modification.
Old Apr 24, 2004 | 05:27 PM
DSRxSALSA's Avatar
Default Re: (RenoRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing &raquo;</TD></TR><TR><TD CLASS="quote">cbr 929 and 954 are all plug and play down to the map, tps, injectors swap out, fpr's and rails are the same fittings. the throttle cable even fits without too much modification.</TD></TR></TABLE>
thanx for the info renoracing
any information like this about the GSXR 1000 itb's???
Old Apr 25, 2004 | 12:33 AM
DSRxSALSA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">There is abolutely no wiring at all when dealing with the GSXR 1000 setup. All you have to do is mount the Honda TPS and then everything is plug and play.</TD></TR></TABLE>
looking more into the gsxr 1000's
ITB's
Old Apr 25, 2004 | 07:55 AM
b18cEK's Avatar
Default Re: which ITB's are plug and play?? (92integGS)
get some 1100cc Honda Blackbird Throttle Bodies!
Make sure they are from a 99 and up Blackbird tho, because the 98 and below were carb'd
I just got some and I believe they are 42mm at the butterflies... Should flow pretty nice
Old Apr 25, 2004 | 07:38 PM
ZigenBallz's Avatar
Default Re: which ITB's are plug and play?? (civic-rmod)
What's the spacing like on the blackbird TB's?
Similar to 929/954's or wider?
Old Apr 25, 2004 | 08:11 PM
user 996328629's Avatar
Default Re: which ITB's are plug and play?? (ZigenBallz)
Im doing my buildup now on the 929's
Old Apr 25, 2004 | 09:17 PM
drunknbass's Avatar
Default Re: which ITB's are plug and play?? (Swags04)
i thought the 00-01 929 and the 01-03 (my dates might be wrong) 954rr were the same throttle body.. 42mm
Old Apr 26, 2004 | 06:18 AM
b18cEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZigenBallz &raquo;</TD></TR><TR><TD CLASS="quote">What's the spacing like on the blackbird TB's?
Similar to 929/954's or wider?</TD></TR></TABLE>
Not quite sure what the cbr929's are....
But I would now recommend going with the 929's or gsxr's due to the fact that they are cheaper and no one has had experience with using the blackbird itb's, so it would probably be easier and cheaper for the other itb's....
Not too sure cause I am new to making my own itb's!
I will let everyone know how mine work when I get them running and I should also have some dyno sheets from Payn Tech in Troy, MI
GSR_Hatch8
Jan 8, 2011 12:35 PM
PINKS
Welding / Fabrication
Mar 3, 2007 02:35 AM
OpTiX619
Dec 9, 2005 02:10 AM
BodyKits NW
Feb 19, 2004 01:57 PM
Ahknodd
May 4, 2003 05:41 PM
