DO i need a resistor box??
Old Apr 24, 2004 | 12:06 PM
derekolerude's Avatar
Default DO i need a resistor box??
i am running a p28? b16 in a 97 coupe do i need a resistor box??? running rc's low impedince injectors
Old Apr 24, 2004 | 03:50 PM
Chiovnidca's Avatar
Default Re: DO i need a resistor box?? (derekolerude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derekolerude &raquo;</TD></TR><TR><TD CLASS="quote">i am running a p28? b16 in a 97 coupe do i need a resistor box??? running rc's low impedince injectors</TD></TR></TABLE>
Yes
Old May 5, 2004 | 11:49 AM
GSR-T-'s Avatar
so he needs it because he has a p28 correct?
Old May 5, 2004 | 12:04 PM
tgreaves's Avatar
Default Re: (GSR-T-)
Heres the deal.. All honda ecus need high-impedance injectors.. If you are using high-impedance injectors then no resistor box.. If you are using low-impedance injectors then you do need the resistor box..
The honda ecu has nothing to do with it.. High impedance or low impedance with resistor box..
jdmdikk
Apr 1, 2009 06:13 AM
boosted96teg
Apr 8, 2008 12:15 AM
boosted96teg
Mar 15, 2008 06:35 AM
jdmray
Oct 23, 2007 06:18 PM
Adam West
Dec 9, 2005 07:16 AM
