Identify ECU wires please!
Old Apr 24, 2004 | 11:37 AM
Civic Hx-T's Avatar
Default Identify ECU wires please!
93 Civic CX hatch
The first ecu wire plug: Fourth wire what is it.
The Third ECU plug: Sixth wire.
What wires are these please?
Old May 2, 2004 | 07:45 PM
Civic Hx-T's Avatar
If someone knows the site that says what each wire is for an obd1 p28 ecu.. that'd help.
Old May 2, 2004 | 07:46 PM
BauleyCivic's Avatar
Risky Business
Default Re: Identify ECU wires please! (Civic Hx-T)
Old May 2, 2004 | 07:47 PM
Civic Hx-T's Avatar
Uhh....
What's VTM?
Thanks Bauley.
Old May 2, 2004 | 08:00 PM
743power's Avatar
Default Re: (Civic Hx-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Hx-T &raquo;</TD></TR><TR><TD CLASS="quote">Uhh....
What's VTM?
Thanks Bauley.</TD></TR></TABLE>
VTM is the vtec oil pressure switch.
Old May 2, 2004 | 08:01 PM
Civic Hx-T's Avatar
Okay good. Thanks.
Old May 2, 2004 | 08:02 PM
IS3Fifty's Avatar
Default Re: (x743x)
damn bauley, did you make that yourself or get it from a site?
Old May 11, 2004 | 11:37 PM
hb_racer's Avatar
Default Re: (TODAeg6)
well, i took out my ecu to look at the mugen chip. When i put it back, a blue and red wire fell off. I didn't know where it went. When I turned the car on, i got a code 21. I couldn't find a blue and red wire in the graph. The colors kinda didn't match. But i did notice that the spot VTEC was empty. So i put the blue and red wire there. VTEC started to work again. So is it safe to assume that the colors may not be correct? I have a p28 in a 93 dx hatch with a b16a sirII.
Oh, where did that picture come from? website???
Old May 11, 2004 | 11:54 PM
743power's Avatar
Default Re: (hb_racer)
red/blue wire is knock sensor, it goes into d3 on the obd1 ecu plug (far right plug, top row of pins, second one from the left)
p28's don't look for a knock sensor though, so that doesnt make any sense.
vtec solenoid wire is yellow/green and goes to A4 (first plug, bottom row, 2nd one in from left)
Old May 12, 2004 | 09:21 AM
hb_racer's Avatar
Default Re: (x743x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x743x &raquo;</TD></TR><TR><TD CLASS="quote">red/blue wire is knock sensor, it goes into d3 on the obd1 ecu plug (far right plug, top row of pins, second one from the left)
vtec solenoid wire is yellow/green and goes to A4 (first plug, bottom row, 2nd one in from left)</TD></TR></TABLE>
I'm guesing either i'm color blind, or the wire colors i have don't match up because Vtec now works when i plugged it into the first plug, bottome row, 2nd one from the left. Go figure?
Rand The Man
Oct 12, 2010 09:00 AM
romoracing
Dec 9, 2005 10:52 AM
Ekay Jay
Sep 7, 2005 02:20 PM
Kalokohan
Jun 28, 2001 11:17 PM
