DSM Injecotr install
I did the install right (i think) and I am getting fuel from all 4 injectors. HOWEVER.....when I would turn the car on I would get a little leak from the top where the injector goes to the fuel rail. Only on the first one and last one...not the middle two. When I turned the car on to idle it...fuel was pouring out like crazy. What did I do wrong as far as the install. The fuel rail is bolted on tight. I have those seals on the top of the injector. I cant think of anything else and I have been messing with this for close to 5 hours
And I did run some searches but I didnt really find any threads with people having crazy leaks
yeah I have no leakage where the injector connects to the manifold.
I just did a nother search for injector leak and I MAY have found my problem.
1)I missed a step an ddidnt lube the rings up with oil
2)Are the seals at the top supposed to be on the injecotr or IN the fuel rail???
ultimatehonda
Jun 21, 2005 03:55 PM
