Any D series warriors here?
Old Apr 24, 2004 | 10:21 AM
RaceProfessor's Avatar
Default Any D series warriors here?
Need some inspiration onto the my current D16a buildup. Just ordered a set of p29's to freshened up the short block and some input on further mods would be helpful and appreciated.
Sam
Old Apr 24, 2004 | 11:20 AM
six sigma racing's Avatar
Default Re: Any D series warriors here? (RaceProfessor)
talk to ParrisEngDyn
Old Apr 24, 2004 | 11:41 AM
TiggsCRX's Avatar
no dyno or slips yet, having slight idle issues right now, but soon. mods in sig seem to be good on the butt dyno. Check with Exospeed they love the D-series. I'm going to be doing the p29 thing soon too hopefully, can you pm me with where you got yours? Thanks. Good luck.
Old Apr 24, 2004 | 02:55 PM
Kendall's Avatar
I've found that the drivetrain is extremely important when dealing with the D series. Find a lightweight flywheel and good clutch, and then get the shortest gear ratio's possible.
Old Apr 24, 2004 | 03:31 PM
TiggsCRX's Avatar
What's the shortest gear combo available for the d series anyhow?
Old Apr 24, 2004 | 03:32 PM
Kendall's Avatar
Default Re: (TiggsCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiggsCRX &raquo;</TD></TR><TR><TD CLASS="quote">What's the shortest gear combo available for the d series anyhow?</TD></TR></TABLE>
I not exactly sure, but I do know that there is an aftermarket 4.9 final drive for d series tranny's. I would think that the 4.9 in an EX tranny would be about as short as they come.
Old Apr 24, 2004 | 04:39 PM
dfoxengr's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
I not exactly sure, but I do know that there is an aftermarket 4.9 final drive for d series tranny's. I would think that the 4.9 in an EX tranny would be about as short as they come.</TD></TR></TABLE>
yes im rpretty sure thats about the best you can do, using a stock tranny.
Old Apr 24, 2004 | 05:54 PM
TiggsCRX's Avatar
Heh, too bad it's all hydro. doh. Ah well, looks like I'll be lookin' at puttin 1-4 from a zc into a crx si tranny.
Old Apr 24, 2004 | 06:04 PM
hondacivic4g's Avatar
Check my signature for curent set up.
Old Apr 24, 2004 | 06:09 PM
dfoxengr's Avatar
Default Re: Any D series warriors here? (hondacivic4g)
u milled your head 1/20th of an inch.. lol. dont you mean .005? as in 5 thous.
Old Apr 24, 2004 | 06:52 PM
Default Re: Any D series warriors here? (hybridvteceg)
yes i milled my head .05 inch or 1.27 mm.
Old Apr 24, 2004 | 07:20 PM
dfoxengr's Avatar
wow thats a whole lot....why did you have to do that?
Old Apr 24, 2004 | 07:46 PM
I didn't have to, but I wanted to bump the compression. The Y7 head and the Y8 head gasket raises compression to 10.1:1. Then I milled the head .05 inch to raise compressionit to 10.6:1 +/-
Old Apr 24, 2004 | 08:23 PM
dfoxengr's Avatar
im sorry now i know youre wrong. .05 inches will raise your compression by like 15-20 ponts not just 5. you do mean 5 thousanths
Old Apr 25, 2004 | 12:06 AM
liam821's Avatar
25 Year Member
Wait 0.05inch is 1.27mm. Ive run a 2mm headgasket (stock is 0.89mm) so thats 1.1mm larger. It gives you like 0.4:1 lower in compression. So by cutting 0.05inch (1.27mm) id imagine it would raise your compression by about 1/2 a point.
Right?
liam
Old Apr 25, 2004 | 12:52 AM
The Internet Tough Guy's Avatar
Default Re: Any D series warriors here? (liam821)
zc 3,4,5 gearsets in a DX tranny with a quaife, srr 4.9 final, and light flywheel will rip. that's the ticket to speed for the D
Old Apr 25, 2004 | 09:05 AM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">Wait 0.05inch is 1.27mm. Ive run a 2mm headgasket (stock is 0.89mm) so thats 1.1mm larger. It gives you like 0.4:1 lower in compression. So by cutting 0.05inch (1.27mm) id imagine it would raise your compression by about 1/2 a point.
Right?
liam</TD></TR></TABLE>
no.
for clarification 1 point is 0.1 (i.e. 10.1:1, add one point is 10.2:1)
.05 is just a ton to mill, plus it decreases the quench area and CC volume. raising compression even more.
Old Apr 25, 2004 | 09:52 AM
TiggsCRX's Avatar
I'm milled .040 and have no problems, don't think that extra .010 makes such a problem. I've heard of people doing .100 before which I've been told is the max for hondas.
Old Apr 26, 2004 | 12:31 AM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">
no.
.05 is just a ton to mill, plus it decreases the quench area and CC volume. raising compression even more.</TD></TR></TABLE>
Ok my bad on the 1point i ment one full point 1 not .1. Never the less I think your wrong about the 0.05 being alot to mill. You will decrease the quench area a little but not enough to really cause a huge increase in compression.
liam
Old Apr 26, 2004 | 12:59 AM
Blind-Fashion's Avatar
i'm currently running p29 pistons on eagle rods with a reground z6 cam on a y8 head with crower springs and i have yet to dyno it.. pulls pretty hard to 8200 (rev limit)..
Old Apr 26, 2004 | 04:03 AM
TiggsCRX's Avatar
uh, what ecu you running with that z6 cam in the y7 head and what block? stock rev limit is like 7200 and fuel cuts at 7500.... of course, could just be an issue of the stock tac being so innacurate...
Old May 3, 2004 | 05:29 PM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceProfessor &raquo;</TD></TR><TR><TD CLASS="quote">Need some inspiration onto the my current D16a buildup. Just ordered a set of p29's to freshened up the short block and some input on further mods would be helpful and appreciated.
Sam </TD></TR></TABLE>
Get rid of the a6 head and get yourself a z6 head and a Crower 2 cam. The type of profile you will need to make alot of power with that non-vtec head will really kill your drivability. That said, the vtec head obviously gives you the luxury of the 2 diff. spec profiles for a really broad seamless powerband. Portmatch the head to a y8 intake manifold and possibly a 62mm TB, and get a true vtec ecu to run the thing, such as the p28.
http://www.d-series.org is ya friend
Old May 3, 2004 | 06:28 PM
ParrisEngineDynamics's Avatar
Default Re: Any D series warriors here? (builthatch)
Keep the A6 head, weld the combustion chambers, have some nice headwork (exospeed race package with cam) and be on your way. Yes you will probably sacrafice drivablility given the profile of the cam. Modify your ecu, some nice headers, and you will be having fun. And for those who wanna get a little more crazy, go with the dual side draft carb set up like me And forget about all that fuel management crap Good luck and have fun.
PARADOX_sf
Jun 5, 2017 03:56 AM
ladiesloveej
Nov 16, 2009 08:13 AM
dj4monie
Feb 22, 2008 05:25 AM
ivt-t
Jul 20, 2007 08:53 AM
zczac
May 28, 2004 01:17 AM
