mini me swap questions???? 89 CRX SI D16Y8 HEAD
Old Apr 24, 2004 | 08:56 AM
BLOWN89SI's Avatar
Default mini me swap questions???? 89 CRX SI D16Y8 HEAD
IF I RUN THE D16Y8 HEAD WILL THE ECU NEED ADAPTED TO MY HARNESS? OR DOES SOMEONE MAKE AN ADAPTERHARNESS?? HOW CAN I RUN A RPM SWITCH TO CONTROL VTEC?? WILL I NEED ANYTHING ELSE TO COMPLETE THE SWAP??
ANYONE????
Old May 10, 2004 | 02:58 PM
simplypinoyy's Avatar
Default Re: mini me swap questions???? 89 CRX SI D16Y8 HEAD (BLOWN89SI)
Apexi V-afc... my boi has the same setup
Old May 10, 2004 | 03:13 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLOWN89SI &raquo;</TD></TR><TR><TD CLASS="quote">IF I RUN THE D16Y8 HEAD WILL THE ECU NEED ADAPTED TO MY HARNESS? OR DOES SOMEONE MAKE AN ADAPTERHARNESS?? HOW CAN I RUN A RPM SWITCH TO CONTROL VTEC?? WILL I NEED ANYTHING ELSE TO COMPLETE THE SWAP??
ANYONE????</TD></TR></TABLE>
No need to yell...but...there's an ECU alternative to this besides using a VAFC. You can run an 89-91 B16A PR3 ecu and have it reprogrammed to comply with your mini-me setup. If you happen to come up on a PR3 ecu, hit me up and I can reprogram the PR3 to work with your mini-me.
Old May 15, 2004 | 03:40 PM
BLOWN89SI's Avatar
Default Re: mini me swap questions???? 89 CRX SI D16Y8 HEAD (Katman)
SO CAN I USE THE V-AFC INSTEAD OF CHANGING THE ECU??
Old May 15, 2004 | 08:31 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLOWN89SI &raquo;</TD></TR><TR><TD CLASS="quote">SO CAN I USE THE V-AFC INSTEAD OF CHANGING THE ECU?? </TD></TR></TABLE>
I hear you can, but its better to use a VTEC ecu vs. a non-vtec ecu + VAFC, because of the programming a VTEC ecu has 2 sets of fuel & timing maps (1 set before vtec crossover and another set while in VTEC), whereas the non-vtec ecu only has 1 set of fuel & timing maps. So you're not really running at optimum power using a non-vtec ecu + VAFC on your setup. VTEC will kick on regardless, because of the VAFC, but your VTEC fuel & timing maps aren't there.
cr-rex88
Oct 22, 2014 11:17 AM
CR3X
Nov 27, 2007 08:37 PM
aja345
Apr 21, 2007 09:48 AM
spoonvtec101
Aug 11, 2003 08:34 PM
PaImportTuner
Nov 5, 2002 07:48 PM
