installing clutch cable
Old Apr 24, 2004 | 05:56 AM
dFreezy's Avatar
Default clutch cable adjustment
my clutch cable snapped last week, so its time to install a new one. the last time i tried installing it myself, i had trouble fitting the one end onto the control arm. i could use some suggestions or advice, i remember reading people installing these without a problem.
Modified by bl@sterVT at 6:57 PM 5/4/2004
Old Apr 24, 2004 | 06:21 AM
HamiltonRex's Avatar
Default Re: installing clutch cable (bl@sterVT)
I just removed mine the other day.
First thing, route it from the engine bay though the firewall and get that hooked up to the pedal, it just kinda clips in.
Next route it to the area where its gonna hook up, it was over the intake manifold for me, then down to the tranny. Then on the cable there should be like a threaded adjusted, back it off ALL the way. Then slip the cable onto the arm, and tighten up the adjusted JUST untill you feel tension, no more no less.
This is on a B series cable tranny in a Crx
-Eric
Old Apr 24, 2004 | 08:18 AM
dFreezy's Avatar
Default Re: installing clutch cable (HamiltonRex)
i just got it in...thanks for the reply. i think what happened last time is that i bought the wrong cable, probably the one for the wagon/4wd because my clutch was soooo tight before.
Old May 4, 2004 | 02:56 PM
dFreezy's Avatar
now i seem to be running into the problem of adjustment...it seems if i adjust the cable too tight, the clutch pedal is stiff as hell, but will engage. this kind of pressure will probably be too much for the cable and make it snap within a few months (like my previous one did). on the other end, if the adjustment is too loose, the clutch pedal is soft (like it should be), but will only engage if i smash it all the way to the floor. in this case its hard to shift, but will only grind for reverse. there isnt even a full turn on the clutch cable adjustment so i was thinking there is a possibility of a bigger problem..perhaps the clutch itself is dying? the small "weight" thats bolted onto the clutch control arm actually fell off my car a while back, but i didnt think it would affect my clutch that much...any opinions?
Old May 4, 2004 | 03:11 PM
spaceman's Avatar
Default Re: clutch cable adjustment (bl@sterVT)
whats your car/motor and what cable are you using?
Old May 4, 2004 | 03:13 PM
crashtest Sonny's Avatar
Default Re: clutch cable adjustment (spaceman)
i did mine like few weeks ago..i didnt realize how easy it was.
Old May 4, 2004 | 03:31 PM
EL Vap133's Avatar
I used a 90 Teg clutch cable in my B16 crx and it works just fine.
Old May 4, 2004 | 04:30 PM
payneth's Avatar
Default Re: clutch cable adjustment (EL Vap133)
its cake
Old May 4, 2004 | 05:44 PM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">whats your car/motor and what cable are you using?</TD></TR></TABLE>
stock d16 with oem replacement cable from autozone
its not the installation im having problems with, its the actual adjustment. i have a feeling that the missing piece that bolts onto the clutch control arm might be cause of this problem. does anyone know what part im referring to? i dont know the exact name...
Old May 4, 2004 | 05:50 PM
Rywire's Avatar
A honda oem part is a way better unit (less chance of breakage). Do you know how to properly adjust it? That may be your problem. Grab the arm, and shake it up and down. Give it like a 1/8 inch of free movement. Ryan
EDIT, adjust by turning the nut.
turbo-crx
Oct 7, 2008 02:45 PM
pauley01
Jan 22, 2007 10:43 AM
EKIM NART
Mar 12, 2006 06:06 PM
Sirex
Sep 26, 2003 07:55 AM
