.....I searched....headlight removal question.....
Ok, this may be really idiotic.....but I'm just making sure I'm not missing something. Was going to throw some city lights in my 95' coupe.....Do I have to remove the bumper to pull the headlights? If not there any trick to it?
also, off-topic, but a "EG" "EK" etc.......my coupe would be an EK right? Is that the JDM designation for a coupe or what? Never read what means what anywhere...........
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erod »</TD></TR><TR><TD CLASS="quote">Ok, this may be really idiotic.....but I'm just making sure I'm not missing something. Was going to throw some city lights in my 95' coupe.....Do I have to remove the bumper to pull the headlights? If not there any trick to it?
Just a little but youll never know unless you ask right?
I dont need to take my bumper off but thats because i set it up so i dont have to. But usually you just need to take off like 2 screws and pull it back a little. Also by the 2 screws for the bumper is a bolt you have to take off. Then the 2 on the top.
No you have a EJ if you want to be specific. And a EJ1 is a USDM Civic Coupe EX and a EJ2 is the same but a DX. "EK" is 96-00 civic hatches. Also a EG is really a EH in america, EG is JDM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Just a little but youll never know unless you ask right?
Exactly.
Thanks for the clarification(s)
Exactly.
No you have a EJ if you want to be specific. And a EJ1 is a USDM Civic Coupe EX and a EJ2 is the same but a DX. "EK" is 96-00 civic hatches. Also a EG is really a EH in america, EG is JDM. </TD></TR></TABLE>
also coupes
also coupes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hotcivicSi »</TD></TR><TR><TD CLASS="quote">
also coupes </TD></TR></TABLE>
Actually 4drs (as i just learned right now) not coupes. Apparently coupes are EJ1's as well ::shurgs::
6th Generation (1996-2000)
EG1 D15B8 USDM 1996-1997 del Sol (8-valve)
EG1 D15B7 USDM 1996-1997 del Sol S (SOHC)
EG1 D15Z1 USDM 1996-1997 del Sol VTEC-E (SOHC)
EG2 B16A2 USDM 1996-1997 del Sol VTEC (DOHC)
EH6 D16Z6 USDM 1993-1995 del Sol Si (SOHC)
EJ1 D16A JDM All 2-door
EJ3 n/a JDM All 2-door / 4WD
EJ6 D16Y7 CANADA All 2-door DX/Si
EJ6 D16Y7 CANADA 2000 2-door DX-G
EJ6 D16Y7 CANADA 1996-1998 3-door CX/CX-G
EJ6 D16Y7 CANADA 1999-2000 3-door CX/DX
EJ6 D16Y7 CANADA 2000 3-door SE
EJ6 D16Y7 CANADA All 4-door LX/EX
EJ6 D16Y7 USDM All 3-door CX/DX
EJ6 D16Y7 USDM All 4-door DX/LX
EJ6 D16Y7 USDM 1999 4-door DX-V
EJ7 D16Y5 USDM All 2-door HX (VTEC-E)
EJ8 D16Y8 CANADA All 2-door EX
EJ8 D16Y8 USDM All 2-door/4-door EX
EK2 D13B JDM All 3-door/4-door
EK3 D15B JDM All 3-door/4-door
EK4 B16A JDM All 3-door/4-door
EK5 D16A JDM All 4-door 4WD/LEV
EK8 D16A JDM All 4-door 4WD/LEV
EK9 B16B JDM All 3-door Type-R
EM1 B16A2 CANADA 1999-2000 2-door SiR
EM1 B16A2 USDM 1999-2000 2-door Si
Info from this thread:
https://honda-tech.com/zerothread?id=694733
Hey Luser, you don't have any 5th gen on that list. An easy way to determine your chassis code is look at the 4th-6th digits of your VIN. I drive an EJ2 - 94 DX coupe with a d15b7 engine.
Yes you need to remove the front bumper, which is not hard at all.
Remove the phillips screws on the bumper where the hood closes.
Remove the two screws (or bolts) from each side where the bumper meets the fenders
Remove the 10mm bolts on the bottom side of the bumper
Pull the bumper cover off.
Then remove the 10mm bolts (4 I think?) that hold the little metal headlight stays to the bumper bar.
Then remove the 10mm bolts that hold the actual headlight housings in.
Done.
Done.
Coolio.
Man, think I'll take my clubsi.com stickers off. You people are actually helpful, and and 5x less asanine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erod »</TD></TR><TR><TD CLASS="quote">Coolio.
Just give it some more time. You'll see some dicks here too.
Seriously though, we all appreciate someone who searches before posting a topic or a question.
If you need anything else just search, and if you can't find it post a new topic and make sure you add "already searched" so the lamer "do a search!" people don't dogpile on you.
And if you ever have any issues with anyone herem let me know - I'll help out in any way possible seeing as how I moderate this forum (we have two others too.)
you don't need to take your bumper off loosen the two screw that hold the front of your fender on and when you pull your lights out just lift the front of the fender up a little bit and there you have it headlight out. i put projectors on my 93 4 door civic i know it can be a pain in the ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
And if you ever have any issues with anyone herem let me know - I'll help out in any way possible seeing as how I moderate this forum (we have two others too.)</TD></TR></TABLE>
oh, believe me, I know. I've been around j-body.org forever, (there is a real brain-trust, too. hahah) and don't know how many times I've said "search, that was posted like last week"
Anyhow, thanks.
Anyhow, thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Just give it some more time. You'll see some dicks here too.
what!? not here Tom!
Yes, do give it some more time before passing final judgment. You've been lucky so far.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 »</TD></TR><TR><TD CLASS="quote">Hey Luser, you don't have any 5th gen on that list. An easy way to determine your chassis code is look at the 4th-6th digits of your VIN. I drive an EJ2 - 94 DX coupe with a d15b7 engine.</TD></TR></TABLE>
5th Generation (1992-1995)
EG1 D15B JDM All 3-door/4-door/CR-X
EG1 D15B8 USDM 1993-1995 del Sol (8-valve)
EG1 D15B7 USDM 1993-1995 del Sol S (SOHC)
EG1 D15Z1 USDM 1993-1995 del Sol VTEC-E (SOHC)
EG2 B16A JDM All 3-door/4-door/CR-X
EG2 B16A3 USDM 1994-1995 del Sol VTEC (DOHC)
EG3 D13B JDM All 3-door/4-door
EG4 D15B JDM All 3-door/4-door/CR-X
EG5 n/a JDM All ? (ZC DOHC)
EG6 B16A JDM All 3-door/4-door/CR-X
EG7 D13B JDM All 3-door/4-door
EG8 D15B JDM All 3-door/4-door/CR-X
EG8 D15B7 USDM All 4-door DX/LX
EG9 B16A JDM All 3-door/4-door/del Sol CR-X
EH1 n/a JDM All 4-door/4WD (ZC DOHC)
EH2 1.5L USDM All 3-door CX/VX/DX
EH3 D16Z6 USDM 1993-1995 3-door Si
EH9 D16Z6 USDM All 4-door EX
EJ1 D16Z6 USDM All 2-door EX
EJ2 1.5L USDM All 2-door DX
There all on that link that i provided on my last post.
mrctr
Jun 5, 2004 10:59 AM
