cluster not lighting up
Old Apr 23, 2004 | 06:57 PM
deez nuts's Avatar
Default cluster not lighting up
i thought that my old cluster was messed up but i just got another one and it's not lighting up.... any ideas? this sucks because i can't see how fast i'm going and can't see my rpm
Old Apr 23, 2004 | 07:22 PM
Kasper.'s Avatar
Default Re: cluster not lighting up (aLL MoToR eF cRx)
uuuhhh do the obvious and check your fuses.
Old Apr 23, 2004 | 08:20 PM
deez nuts's Avatar
Default Re: cluster not lighting up (Kasper-EF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kasper-EF8 &raquo;</TD></TR><TR><TD CLASS="quote">uuuhhh do the obvious and check your fuses.</TD></TR></TABLE>i did..
Modified by aLL MoToR eF cRx at 7:09 AM 4/24/2004
Old Apr 23, 2004 | 10:52 PM
Origin's Avatar
do you still have the dimmer switch hooked up. i believe theres a switch on both the left and the right. if those are unplugged the gauges wont light up. i know that was my problem at least. i had fully removed the interior and just removed the whole dash assembly with the dimmer switch and whatever that other switch was so i ripped it back out of the dash and hooked it up and all was good again. if that doesn't work then look through the wiring and make sure everything is okay.
Old Apr 23, 2004 | 11:19 PM
Mr_CRX's Avatar
Default Re: cluster not lighting up (Origin)
definitely check that dimmer switch. i had one go bad and the cluster would work fine, just not light up.
Old Apr 24, 2004 | 06:47 AM
deez nuts's Avatar
Default Re: cluster not lighting up (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">definitely check that dimmer switch. i had one go bad and the cluster would work fine, just not light up.</TD></TR></TABLE>checked the dimmer switch and played with it for awhile. i didn't take out the dash though just the cluster cover. you guy thinks theres something wront with the wiring? you guys think the dimmer needs to be raplaced
Old Apr 24, 2004 | 06:58 AM
spaceman's Avatar
did you do any kind of swap?...when was the last time the cluster worked?..check the wires and grounds
Old Apr 24, 2004 | 08:52 AM
krazie1's Avatar
BANNED
Default Re: cluster not lighting up (spaceman)
okay I had my dimmer go out here is a way to check
take a paper clip and stick it in the pins
u should see it light up to the brightest setting
and if that don't work check ur power to the lights in the dash
first do the easy things and then move on to the more stressful things
Old Apr 24, 2004 | 10:41 AM
deez nuts's Avatar
Default Re: cluster not lighting up (krazie1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">okay I had my dimmer go out here is a way to check
first do the easy things and then move on to the more stressful things</TD></TR></TABLE> the paper clip where? more details? my clock works and all the other lights. this **** is wierd
Old Apr 25, 2004 | 07:22 PM
deez nuts's Avatar
Old Apr 26, 2004 | 03:36 PM
deez nuts's Avatar
bump
Old Apr 29, 2004 | 08:13 PM
deez nuts's Avatar
bump
Old Apr 29, 2004 | 09:27 PM
krazie1's Avatar
BANNED
u know where the dimmer swqitch is at unplug it and stick the clip in there and u should see light or not
if u don't woh something ain't rockin' in that harness or fuse box of ur's
Old Apr 29, 2004 | 11:04 PM
mr. carpenter's Avatar
there are three light bulbs inside the cluster on top and also numerous other lights. also make sure the wiring harness contact points are clean
xxjasonxx
Nov 20, 2008 06:08 PM
BYAAH85
Feb 19, 2008 11:35 AM
DiMpL3s
Jan 6, 2008 11:32 PM
DC5Danny
Mar 22, 2007 08:01 AM
whiteef-8
16
Feb 24, 2005 05:45 AM
