Need help locating a wire for alarm install
Whats up guys,
I'm installing an alarm into my 1993 Civic and need help locating the dome light/door trigger wire to tap into. Does anyone know what color it is and were it is located? This is the last thing i need to do. Thanks for any help!
try looking at the vehicle information at http://www.the12volt.com. All the info is there.
1992 Honda Civic Security Information
Constant 12V+ / White / Ignition Switch Harness
Starter / Black/White / Ignition Switch Harness
Ignition / Black/Yellow / Ignition Switch Harness
Accessory / Yellow / Ignition Switch Harness
Tach / Blue / Distributor
Brake Switch / Green/White / Brake Switch
Trunk Pin / Green/Black (-) /Above Fuse Panel Blue Connector
Parking Lights / Red/Black / Above Fuse Panel White Connector
Head Lamp / Red/White / Steering Column
Hood Pin / n/a
Factory Disarm / Disarms w/Unlock
Door Trigger / Green/Red (-) / Driver's Running Board One of Two Wires
Door Lock / Green/White (-) / In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
Door Unlock / Green/Red (-)
Horn Wire / Blue/Red (-) / Steering Column, use Relay
Windows Up / LF=Red/Blue, RF=Blue/Yellow
Windows Down / LF=Red/Yellow, RF=Blue/Green
This is copied and pasted from another site so I am not sure if they are correct or not!
Hood Pin / n/a
AznMTboy
Jun 27, 2005 05:25 PM
