AC on a GRS swap
I have a GSR swap into a '94 Del Sol, and i need ac. I have herd that the DOHC del sol vtec bracket is what i need, along with some tensioner. So i called Honda to see how much it was. He had no clue as to what a DOHC was, and quoted me $30. I knew this was wrong so i didn't order it. So does anybody know where i cas get one, that will for sure work, along with a tensioner, or does anybody know any part numbers for the right one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura delsol »</TD></TR><TR><TD CLASS="quote">I have heard that it wont work that way, because the lines for the ac wont connect to the GSR compressor.</TD></TR></TABLE>
your right, they wont, the AC line connectors point a different way than on integras.
you could swap your civic lines for integra ones
to physically attach the compressor (del sol) to the motor you'll need the del-sol-vtec compressor mount. don't have part numbers. can get it on classifieds...
edit ... here you go
http://www.hondaautomotivepart...EC%29
Modified by miahmouse at 7:14 PM 4/24/2004
bossman032
18
Dec 23, 2008 03:35 PM
