Compression on jdm itr block with ctr cams with stock head gasket??
Old Apr 23, 2004 | 05:30 PM
jdmitrhatch's Avatar
Default Compression on jdm itr block with ctr cams with stock head gasket??
I have a jdm itr motor, but i am wanting to boost compression for jun 3's....i think im gonna go ctr pistons and a smaller head gasket...what exactly should i do...i have been told to get as close to 12.5:1 as possible for the best results with the jun 3's...so what will the ctr pistons do for me...?? or what u think i should do?
Old Apr 23, 2004 | 06:56 PM
b16supertuner's Avatar
Default Re: Compression on jdm itr block with ctr cams with stock head gasket?? (jdmitrhatch)
i took my 98 JDM ITR motor and milled the head .020" and am running a mugen headgasket. C-speeds compression calculator ploted my static comp ratio at 12.03:1
Old Apr 24, 2004 | 05:12 PM
Default Re: Compression on jdm itr block with ctr cams with stock head gasket?? (b16supertuner)
ya, i dont want to cut up my head though
Old Apr 25, 2004 | 07:28 PM
where do i find the c-speed compression calculator
Old Apr 25, 2004 | 07:35 PM
gamakichi77's Avatar
go to http://www.c-speedracing.com
inside this websites, there's a lot of technical info good for you.
its not a device or calculators.
LvN
Mar 17, 2006 09:38 AM
Slow96RedEk
Nov 17, 2003 08:36 AM
b18c-rDC2
Mar 12, 2003 01:27 PM
Ruby Civic
Sep 7, 2002 11:40 AM
COREY ITR#625
Sep 30, 2001 01:45 PM
