5$ paypal to the first one that can solve this, seriously. vtec not working only at track.
Old Apr 23, 2004 | 05:24 PM
EGmikeH22's Avatar
* B A N N E D *
Default 5$ paypal to the first one that can solve this, seriously. vtec not working only at track.
i have a 92 civic VX hatch
with a JDM H22a
everything works on the street, it runs vtec and everything. i got it to run vtec one time at the track, but it always throws code 6, temp sensor. I have a fluidyne civic radiator, and otherwise a stock prelude / accord cooling system. i have a new water pump.
i also have codes for 02 sensor ground, and idle air controller. These seem to just be wired incorrectly, but everyhting works. just when i am at the track, i get no vtec.
5$ to one of you is not close to the 20$ to test and tune fridays at my gay *** local stip.
the one time i ran with vtec i had a 13.7 @ 101 wtih a 2.1 60'
i have afalken azenas on rota circuit 8s.
again 5$ paypal to the first one that tells me why this happens AND what i can do to fix it.
i have tried turning the car off in the staging (2-7 mins) and idleing it, and revving for about a min before i run.
also my fan never turns on, it used to always be on, until i wired that one coolant sensor that is now causing the issue..
goooood luck
MIKE
Old Apr 23, 2004 | 05:36 PM
vtec94civic's Avatar
Default Re: 5$ paypal to the first one that can solve this, seriously. vtec not working only at track. (EGm
i'm not sure if this is right but i'm going to take a shot at it. you said something about the fan never coming on right? maybe there is something wrong with the temp sensor and the ecu is getting a false reading saying that the engine is cooler than what it really is and since its reading that it isn't at its normal operating temp then vtec won't active and also your fan won't come on since it thinks that the engine isn't hot enough to turn on the fan. i don't know if this is what you are looking for, but hey it was worth a try.
Old Apr 23, 2004 | 05:56 PM
2lua's Avatar
look like you have quite a fews cel. why don't you fix all those cel, and see your car run any better. if not come back for more info.
the reason for the vtec not activate because the oil is not at proper temp, or level.
Old Apr 24, 2004 | 07:20 AM
cccya's Avatar
Default Re: (2lua)
fix your cel first, then make sure you are up to temp, before you make a pass down the track. vtec will not work, if you are not up to temp!!!
HTH
92lx
Nov 10, 2012 11:55 AM
t-dizzy
May 18, 2008 01:44 PM
LsVtakYO
Dec 5, 2005 10:54 AM
mikebranson
Apr 13, 2004 09:00 PM
jonas
Mar 15, 2003 03:09 PM
