b18 vtec block with b16 head..what head gasket? b16 or b18 or are they both the same?
Old Apr 23, 2004 | 03:31 PM
Grip's Avatar
Default b18 vtec block with b16 head..what head gasket? b16 or b18 or are they both the same?
i have a b16 right now..i wanna buy a b18 vtec block because i want more tourqe and the b18 seems like a better block then the b16 when it comes to that..i was wondering what headgsaket i can use..i allready have a new mugen headgasket sitting in my room...can i use a b16 head gasket or do i need a b18 headgasket? or are they both the same? im guessing they are the same since my headgasket dosent say b16 or b18 on the wrapping..ijust wanna be sure
Old Apr 23, 2004 | 03:38 PM
kron0ne's Avatar
Default Re: b18 vtec block with b16 head..what head gasket? b16 or b18 or are they both the same? (Grip)
What ever block you use, use that head gasket, and what ever oil pump you use, use that timing belt
Greg S.
Old Apr 23, 2004 | 03:48 PM
agreziv89ef-8's Avatar
it will fit its a bseries head gasket
Old Jun 1, 2004 | 07:38 AM
hondaguyef's Avatar
Default Re: b18 vtec block with b16 head..what head gasket? b16 or b18 or are they both the same? (lsi crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsi crx &raquo;</TD></TR><TR><TD CLASS="quote">What ever block you use, use that head gasket, and what ever oil pump you use, use that timing belt
Greg S.</TD></TR></TABLE>
Don't you mean water pump? the oil pump is driven by the crankshaft.
Old Jun 1, 2004 | 07:57 AM
nickgmiller04's Avatar
Default Re: b18 vtec block with b16 head..what head gasket? b16 or b18 or are they both the same? (hondaguye
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Don't you mean water pump? the oil pump is driven by the crankshaft. </TD></TR></TABLE>
werd
Old Jun 1, 2004 | 09:51 AM
senselessviet's Avatar
im planning on doing the same but still cant find a gsr block for a good price
Old Jun 24, 2004 | 01:47 PM
jdm_loser's Avatar
Default Re: b18 vtec block with b16 head..what head gasket? b16 or b18 or are they both the same? (senseless
do what im doing
brand new block from acura b18c5 only have 1500 need about another ggrand but it will soon come
Old Aug 13, 2004 | 05:53 PM
PahLok's Avatar
Dumb question now,
So a B18 block will fit directly to a B16 head without any mods and with the normal B series gasket, is that it?
Old Aug 13, 2004 | 05:59 PM
Forrest Gump 9's Avatar
b18C will fit with b16 head without any modification, b18a or b will need oil line for the Vtec, hence the Ls/Vtec.
Old Aug 13, 2004 | 06:11 PM
PahLok's Avatar
Thanks.
I have a B16A2 and wanted to upgrade the displacement to 1800cc. Best solution would be to get a B18C5 block, which I can get from Honda here in Portugal.
Thing that is worring me is if the block comes with an engine code and number. This way police would hassle me . I have seen engine blocks that have no code or number on them, which is ok and police won´t give you any trouble, you´ll just say you blew up your old engine and that you fitted the same type of new engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo9Nut &raquo;</TD></TR><TR><TD CLASS="quote">b18a or b will need oil line for the Vtec, hence the Ls/Vtec.</TD></TR></TABLE>
I didn´t understand this part.. but I guess it doesn´t have nothing to do with the mods I´m thinking off.
Modified by Soichiro Honda at 3:36 AM 8/14/2004
mymeatb18"
Jul 8, 2006 11:11 AM
Blazin Civic
Jun 15, 2005 03:38 AM
civcexcoupeblack
Jan 17, 2005 09:03 PM
EG-cellent
Apr 14, 2003 06:01 AM
