Need part number on Mugen N1 ECU...
Old Apr 23, 2004 | 02:12 PM
iperez's Avatar
Default Need part number on Mugen N1 ECU...
Like the topic says, I need to know the part number on the side of the Mugen N1 ECU. Basically, I need to know if its a P28, P73 or what !! Thanks !!
Old Apr 23, 2004 | 02:27 PM
BlueR's Avatar
Default Re: Need part number on Mugen N1 ECU... (iperez)
mugen doesn't use stock honda ecus
"This is a complete Mugen replacement non-programmable ECU. Mugen does not produce or sell ECU chips, stock ECUs with replacement chips, or programmable ECUs."
Modified by BlueR at 6:44 PM 4/23/2004
Old Apr 23, 2004 | 02:44 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">Like the topic says, I need to know the part number on the side of the Mugen N1 ECU. Basically, I need to know if its a P28, P73 or what !! Thanks !!</TD></TR></TABLE>
None of the above.
I have one sitting here but an exterior pic won't do you any good!
Old Apr 23, 2004 | 02:45 PM
Big Phat R's Avatar
From King Motorsports website re: N1 ECU
I used to have one of them - they are not like any Honda ECU. They use an OBD1 harness though.
Old Apr 23, 2004 | 02:57 PM
ZygSpeed's Avatar
Default Re: Need part number on Mugen N1 ECU... (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote"> They use an OBD1 harness though.</TD></TR></TABLE>
Plugs into a 97 w/o an adapter harness.
iperez's Avatar
That is EXACTLY what I am looking to find out .. So the Mugen N1 is in fact an OBD1 ?? The situation is that I bought the harness from a friend who was using a Mugen N1 on his 2001 ITR and it worked fine.. However, when I installed the harness on my 2001 ITR with a JUN ECU (P73) I'm seeing several problems.. If the Mugen N1 is OBD1 that would make sense because the JUN P73 is OBD2a ..
Old Apr 23, 2004 | 03:04 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">That is EXACTLY what I am looking to find out .. So the Mugen N1 is in fact an OBD1 ?? The situation is that I bought the harness from a friend who was using a Mugen N1 on his 2001 ITR and it worked fine.. However, when I installed the harness on my 2001 ITR with a JUN ECU (P73) I'm seeing several problems.. If the Mugen N1 is OBD1 that would make sense because the JUN P73 is OBD2a .. </TD></TR></TABLE>
this should have been your initial question instead of the blurb in your first post
Old Apr 23, 2004 | 03:10 PM
iperez's Avatar
Ouch man !! Be gentle, I've had a long day I figured with the ECU number I could cross-reference it and find out if it was OBD1 or what .. but thanks anyway !!
Old Apr 24, 2004 | 01:45 PM
mugenracer's Avatar
37820-XH4 is mugens part number for the DC2 ITR ECU. and if anyones interested:-
37820-XG5 is the EG6 ECU
37820-XG3 is the EK4 ECU
Old May 3, 2004 | 06:59 AM
iperez's Avatar
Default Re: (mugenracer)
Does anyone have a picture of the Mugen ECU where the harness is connected ? I want to see where the pins are located.
Old May 3, 2004 | 07:15 AM
ZygSpeed's Avatar
Default Re: (iperez)
I'm short of storage space but will leave these up for a couple days for you. Ed
DB8
Sep 10, 2008 11:04 PM
carboy_honda
Honda Fit
Sep 4, 2007 08:30 PM
Snoppy
Feb 15, 2004 08:01 PM
slowassR
Aug 1, 2002 05:24 PM
