Tips on removing the climate control?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris »</TD></TR><TR><TD CLASS="quote">cable is located on the passenger side of the console, behind where the lighter is..</TD></TR></TABLE>
That shouldn't be a problem since I'm missing the whole ashtray and lighter console.
If you look under your dash on the passenger side you will see a cable connected to a metal post. Just pull the cable off the post and you should be fine.
Here are some pictures from team-integra.net
yes, the cable is attached to the cold/hot dial, its a real bitch to get the 3 pieces of that climate control apart to take the cable off of the climate control unit, just pull the cable out with it, take note of how the cable is routed through the center console for when you reinstall it, otherwise you may not be able to reach full hot or cold.
turboman
Nov 16, 2005 09:26 PM
