autometer oil pressure gauge and greddy block adapter problem!
i've got a electric oil pressure gauge and the greddy block adapter, but the sender won't screw into ANY of the ports on the adapter. from what i can read on the back of the adapter packaging (everything in different language) is that the two smaller ports are 1/8 and the sender male end is 1/8. so, as you can see, i'm a little confused. thanks in advance guys.
Depending on what engine you are running depends on what you need. I know for the obd0 b16a you don't need an adapter. I assume that for all other B-series that this is also true. But for the D16/15 you need a BSP to NPT adapter. That is to screw it into the stock oil pressure sending unit port.
all Bseries need the bspt-npt 1/8" adapter if you are going off the oil sneding unit. im asking about how many ports and what sizes on the greddy plate adapter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">all Bseries need the bspt-npt 1/8" adapter if you are going off the oil sneding unit. im asking about how many ports and what sizes on the greddy plate adapter.</TD></TR></TABLE>
Same with the Greddy oil block adaptor plate bsp-npt.
you will need a 1/8 bspt-npt 1/8" adapter... best bet is to run the adaptor to the block and put the sending unit on your fire wall using braided steel line....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">ok so thers 2 1/8th bspt portson the greddy right?</TD></TR></TABLE>
correct
correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paybac4223 »</TD></TR><TR><TD CLASS="quote">you will need a 1/8 bspt-npt 1/8" adapter... best bet is to run the adaptor to the block and put the sending unit on your fire wall using braided steel line....</TD></TR></TABLE>
we're talking about the greddy sandwich here.
really pressurized?
i thought there was no need for pressure for oil feeds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg »</TD></TR><TR><TD CLASS="quote">
correct</TD></TR></TABLE>
someone already answered anyways
to my knowledge there is enough pressure comming out of the block...so no need for pressurized oil feeds. i have a 3ft steel braided line and have no problems.
Philly_NBP_R
May 11, 2006 07:31 AM
vtec69
Mar 12, 2003 07:26 PM
vtec69
Mar 12, 2003 05:54 PM
. Did you ever get it on?
