greddy oil pressure gauge install
i have a question about how the greddy oil pressure gauge installs. do you need to add a T on the back of the block like the autometer gauge requires or does it hook up different. i had heard it hooks up differently, but wanted to confirm.
here is the autometer style connection with the T fitting. (for reference)
thanks.
thanks.
Re: greddy oil pressure gauge install (IN VTEC)
does the greddy need a T fitting though like shown above?
or does it mount "in-line" with the stock unit....i.e. you have the BSPT to NPT adapter -> greddy pressure sender -> stock pressure sender without using any Ts or tubing???
I have found that that running a stainless steel oil line from the back of the block to a distribution nounted on the firewall talkes all the strain off the fitting on the block and it puts the sensors in eyes few for better leak spotting. I have used the loop method and mounting it all on the firewall works much better. Enjoy.
Brett
Brett
Re: greddy oil pressure gauge install (SpoolinCRX)
i currently have the autometer oil pressure gauge routed like the picture above and i hate all the fittings. i thought the greddy one might be different.
thanks for the help guys.
Re: greddy oil pressure gauge install (breaka_1_9)
There's teh option of using a sandwich plate in b/w the oil cooler and the block. The plates have two oil out-lines.
thanks for all the help.
Philly_NBP_R
05-11-2006 07:31 AM
00TypeR
06-28-2004 04:26 PM
vtec69
03-12-2003 10:31 PM
