CRX si rev limit?
it depends on the setup and your ECU, the year of your car and the like, and umm stock tachs are very inaccurate
i have had a Si cluster, and it said i was at 3800 at 70, my LS cluster said 3950 and my GSR cluster says 4200, the best thing to do it run it out in 3rd and see where it is...hitting the limiter in 3rd once will not hurt it
Modified by daidilus at 5:03 PM 4/23/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX »</TD></TR><TR><TD CLASS="quote">well you do have the rev limiter functioning right? it should no let you go past 7k or so</TD></TR></TABLE>
Yeah it bounces at about half way between 7K and 8K in third...However it does look lower in the lower gears becuase the tach is inaccurate like daidilus was saying.
intelB16A
Oct 31, 2006 02:56 PM
