heaviest oil i can use?
Old Apr 23, 2004 | 09:24 AM
serious's Avatar
Default heaviest oil i can use?
what's the heaviest oil i can use in my d16z6? is 10w-50 safe?
Old Apr 23, 2004 | 09:27 AM
skip.two's Avatar
Default Re: heaviest oil i can use? (serious)
why do you need 10w50? 5w30 or 10w30 are the recommended oil weights.
Old Apr 23, 2004 | 09:29 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: heaviest oil i can use? (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">why do you need 10w50? 5w30 or 10w30 are the recommended oil weights.</TD></TR></TABLE>
Echo.
Yes I'd only run 5W30 or at most 10W30.
Old Apr 23, 2004 | 09:38 AM
underpressure02's Avatar
Are you burning oil or have some valve tap? Is that why you want to run a heavy weight oil?
I would run what the other guys said unless there is a reason you need to run a heavy oil.
Old Apr 23, 2004 | 10:56 AM
serious's Avatar
Default Re: heaviest oil i can use? (underpressure02)
i have a slight wrist pin knock, and my mechanic told me to just keep driving it and that it'll probably last a couple more years, but he did recommend i use a heavier oil, especially in the summer time (it get's hot in maryland).
Old Apr 23, 2004 | 11:05 AM
Evs-One's Avatar
Solbros Owns Me
easy way to make the car last a little longer....
I need to run some thicker oil in my 91 4 door....valve stem seals are bad and I'm too lazy to fix it
Old Apr 23, 2004 | 11:06 AM
Padawan's Avatar
Darth ModerVader
Since the engine is on its way out anyway, a thicker oil probably can't hurt. I think I'd go with something like a 10W-40, and throw in an additive like Rislone "Ring Seal", which is intended for engines with worn parts.
Old Apr 23, 2004 | 11:09 AM
dantastic's Avatar
Default Re: heaviest oil i can use? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Since the engine is on its way out anyway, a thicker oil probably can't hurt. I think I'd go with something like a 10W-40, and throw in an additive like Rislone "Ring Seal", which is intended for engines with worn parts. </TD></TR></TABLE>
yea i was thinking 10w-40 too.
Old Apr 23, 2004 | 02:03 PM
goodbyegti's Avatar
no prob with 10w40, in the uk its the standard weight, i use it all the time..
Old Apr 23, 2004 | 03:10 PM
EK45VTi's Avatar
Default Re: (goodbyegti)
I use 10w40 all the time and never had problems... and the previous owner was using the sam oil from day 1st he bought the car... and the manual says 10w40 or 5w30
go with 10w40 and 10w50 can't hurt either...
gooblinn258
May 12, 2014 10:54 AM
ivteccivicboi
Apr 8, 2006 06:09 PM
imonx850
Jul 25, 2005 01:30 PM
WPG_5thgenprelude
May 18, 2005 06:23 AM
HUBB
12
Apr 24, 2004 01:53 PM
