Should i go with this (not fantasy tuning)
Old Apr 23, 2004 | 06:28 AM
menkio's Avatar
Default Should i go with this (not fantasy tuning)
i pulled my head, and have an extra core to pratice with. I've started port matching. I'm having a shop install exospeeds cam, it's an all moter y7. Thansk to igo4bmx i now have a y8 intake, and should have a bored out tb as well portch matched to the intake. Now for the engine...
i was going to buy some ls rods, and get some honda/acrua oem pistons. total seal/oem rings, arp fasterns/head bolts, 2 layer head gasket, milled head, and have it assembled at a local shop. I know the ls rods need clearing/notching or something, wondering how much of a problem this will be. Looking for high compression, would it be good to be around 11:1 + I was going to use stock injectors, aem fpr, walboro fuel pump with a s-afc
i'm on aim, menkio001 msg me up.
Old Apr 23, 2004 | 11:02 AM
menkio's Avatar
Default Re: Should i go with this (DewMota)
Old Apr 23, 2004 | 01:59 PM
menkio's Avatar
as the project rest right now..
i bought a 96 dx 5spd tranny(37k) + shift linkage/shifter 150 shipped, auto to 5spd from arpa (thanks again)
thanks to Bspec18 i now have some ls rods.
the head is pulled, along with all the unrusted/cleaned up and painted susspenion(black, just to protect from elements.. and yes bling i added some silver)
headwork starts asap.
also thanks to igo4bmx i have a y8 intake manifold. so now..
so... here it is.
99 civic sedan.
98 y7 with 23k. pulled in my room.
auto tranny, throw off the back porch, and then used at a early keg party for people to pee on.
ls rods + honda oem pistons
arp fasterns, arp headbolts, y8 headgasket, or 3 layer headgaset if comp too high.
exospeed camshaft
drp valvetrain
y8 im
b16 tb boarded out (The new Spaceballs)
gotta have some input guys,.. i'm really commin along with getting stuff togther, but i gotta have idears, d16a1 pistons too much ? also what about s-afc for tuning ?.. and what ecu do i get, p28 right ?
Old Apr 23, 2004 | 03:02 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
how are you planning to attach those LS rods to the OEM pistons?
stan
Old Apr 23, 2004 | 03:24 PM
menkio's Avatar
Default Re: Should i go with this (Stan D)
gummie bears, and yes i know i need to remove material from the piston
Old Apr 23, 2004 | 03:40 PM
not digging your sarcasm...i was genuinely interested in your method of solving the floating wrist pin issue and it's involved costs Vs. aftermarket piston/rod config.
my set up is almost identical, less my engine is an A6.
A1 pistons should be ok, provided you figure out your fueling and potential detonation issues. clay the engine, mine worked out ok with a Rocket non VTEC cam and ISKY valvetrain.
chip and have your ECU tuned by either one of the PGMFI'ed software of Hond$t$
cheers
stan
94eg5squadMD
May 27, 2009 12:00 PM
jksmith
May 26, 2009 01:54 PM
Bserious
Northern California (Sales)
18
Dec 11, 2005 06:46 PM
zCivic
Jan 13, 2003 03:41 AM
