GSR motor swap into Civic
I'm swapping a GSR motor into a Civic HB, can I use the GSR motor mounts or
do I need different motor mounts?
This is gonna be my first swap and I'm just preparing for things to come.
thanks
thanks
i think i gsr engine just bolts on to the stocked restraints..
imma swap in a year or so.. im gettin info too.. xept im gettin b18c5.. JDM intergra type r w00t..
for a B18C1 into a 97 hatch you need a rear mount from a 99 civic Si. Don't bother trying to modify a GSR rear mount. Matter of fact I think I still have a spare 99 si mount if you need it, for pretty cheap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoeMango »</TD></TR><TR><TD CLASS="quote">for a B18C1 into a 97 hatch you need a rear mount from a 99 civic Si. Don't bother trying to modify a GSR rear mount. Matter of fact I think I still have a spare 99 si mount if you need it, for pretty cheap.</TD></TR></TABLE>
He also needs a SI drivers side bracket and if you want to keep ac your gonna need a P54 ac bracket.
well unfortunately they gave you all the wrong answers..
1 you need a EX or SI engine block mount
2 SI driverside mount
3 SI L bracket and the rest should be fine..also you need a SI harness
some are right some are wrong that has been posted here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kitchale »</TD></TR><TR><TD CLASS="quote">Yeh I'm keeping OBDII.
People kept telling me I need a 96 ECU and this and that so I was
making sure.
thanks</TD></TR></TABLE>
yes you will need the 96-99 ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLB SMZ »</TD></TR><TR><TD CLASS="quote">sorry to hijack, but what about GSR motor into 95 CX?</TD></TR></TABLE>
you will need all integra mounts and linkage and either GSR harness or SI or ex harness from 92-95..and you will need 94-95 gsr ecu and you will need to wire up the vtec wires and IAB...
making sure.
Fuster_Cluck
Mar 25, 2003 06:36 PM
