mpfi swap injector position
how does somebody know which injector is injector 1,2,3,4? does it have any order?
is it like this-->
a) distributor side-->inj 1-->inj 2-->inj3-->inj4-->cam gear side
b) distributor side-->inj 4-->inj 3-->inj2-->inj1-->cam gear side
c) distributor side-->inj 4-->inj 2-->inj1-->inj3-->cam gear side
which one is right? this is all i need to know then im done...thanks.
oh yeah, if anybody is curios to what my setup is...here you go;
z6 head, zc block, zc IM,zc Tranny,zc int shaft, a6 ecu,a6 distributor,90-93 integra axles, hmmm...what else...oh yeah, all of the zc stuff are SOHC.
i hope somebody can help me out.
is it like this-->
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bamer02 »</TD></TR><TR><TD CLASS="quote">b) distributor side-->inj 4-->inj 3-->inj2-->inj1-->cam gear side</TD></TR></TABLE>
Yes it does matter. Choice b) (as I quoted) is the right way.
hey phatrick2332...its me b15nissan...hahahahaha!!!
i still have a problem with my dizzy...i dont know which tab would go on the top part...its kind of confusing...and how does the firing order go? i was thinking of that last night too...
anybody who knows how to install the dizzy...i know it wont be in the upright position...it has to be rotated to fit the "right way"....help me out pls.
ill go do some more research.
thanks.
thanks.
hey thanks ef9.....soo ill just install the plugs in that way right? 4-3-2-1 on the injectors right?
but my next question is how too install the a6 dizzy to the z6 head...can i bolt it up then get my timing corrected?
and which position will give it the stock timing?
thanks.
thanks.
BuddhistPriest87
Aug 30, 2006 09:01 PM
