ITR 22mm Rear Swaybar - who's using, gonna use, or using something else
I know that this has been kinda done before informally w/ 1fastgsr, but not a lot of people replied to that one and it wasn't as conclusive.
Also, can you post which mounting kit you're using...Beaks or BSQ or something you designed yourself.
Where you bought the parts from (ie: A&H, Mike K, Import-specialists, used from a board member, other, etc.)
Other doodads you're using with the ITR swaybar (ie: Prothane bushing kit, tie bars, etc.)
I still haven't installed it yet b/c I'm still waiting on a couple of bolts and a pair of endlink bushing collars.
Beaks mounting kit
Neuspeed rear lower tie bar
Got the parts from a friend in Detroit, MI who worked for a chain of dealerships, including Honda and Acura even tho he stationed at VW and then Mazda-Subaru. Got the parts for cost + 10%. Unfortunately he doesn't work there anymore.
Beaks mounting kit
Why did you post a pic of a strut tower bar?
Anyways, I'm using the ITR sway bar with the BSQ kit.
[Modified by backlash, 7:26 AM 10/31/2001]
Type-R rear swaybar
- 3.5+ years (ordered it from a friend that works at a Acura dealership)
BSQ mounting kit
- 3.5+ years (ordered it from a friend that works at a Acura dealership)BSQ mounting kit
Aside from the bar and the BSQ or Beaks mounting kit, what else is needed, or recomended?
Bushings? Bar-End Links?
[Modified by miketegra, 12:26 PM 10/31/2001]
I am using the ITR rear swaybar with the Beaks kit. Both the BSQ and Beaks kit are good. I've seen the BSQ plates mounted on my friend's integra and no problems there.
I bought the ITR brackets, bushings and endlinks. I forgot, but I'm sure you need those pieces.
1.) 52300-ST7-Z01 rear swaybar ($58.30)
2.) 52315-ST7-Z01 swaybar bushing ($4.40) (2 needed)
3.) 52308-SS0-000 bushing bracket ($5.95) (2 needed)
4.) 52316-ST7-Z00 endlink bushing ($1.75) (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar ($4.90) (4 needed) – this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) ($2.45) (2 needed)
7.) 94050-08080 flange nut (8mm) ($0.50) (2 needed)
Note: all prices are from A&H Motorsports (prices current as of 7/1/2001)
damn thats thorough
does the ITR setup with BSQ kit work for a g2 gsr?
so whats the better way of mounting a rear swaybar like stock in the middle of the lca or at the ends of the lca like progress st and others
Thank you for the wealth of information.
Looks like this will be the next mod after I get my ITR shocks and springs installed !
PS - do you have the part numbers for the ITR shocks (front and rear)?
-=Mike=-
[Modified by miketegra, 4:19 PM 10/31/2001]
-=Mike=-
Here are the Acura parts that will be need:
Ben,
remember to get a longer bolts (an inch longer) and a 1/2" washer for the neuspeed lower tie bar...
stan
stan
ITR with skunk2 reinforcement plates
Using the BSQ kit, bought parts from local Acura dealer. Should have gone through A&H.
I'm very happy with it.
Im using bsq's kit too and it works fine. Doesnt look as great as the beaks but it gets the job done damn well and costs a fraction of the beaks.
ITR rear sway bar/BSQ kit. not installed yet. How does the bsq kit install exactly anywhoo?
no noise! yippee!
