can i use a 87 pg7 ecu?
Old Apr 22, 2004 | 09:48 PM
Gant's Avatar
Default can i use a 87 pg7 ecu?
i heard for some reason 87 pg7s cannot be used because of centrifical advanced? i just bought this ecu and the guy told me he was using it for his dohc zc
Old Apr 22, 2004 | 09:57 PM
Redline130's Avatar
Default Re: can i use a 87 pg7 ecu? (Ba4)
Assuming this is for an 88-91, you can only use 88-89 ecu's.
Old Apr 22, 2004 | 10:02 PM
t0eKnEe's Avatar
he was prolly using it on his brown top 87 d16a1 which ppl like to call zc's. Cant use it because on the 87's the distributors use that vacume advance shyte.
Old Apr 23, 2004 | 06:42 AM
T S R Performance's Avatar
Default Re: can i use a 87 pg7 ecu? (t0eKnEe)
if you have 88-91 civic with a multiport conversion or if its an Si you can use it...they rev up to 7600. it wont work with dualpoint. And it will make you run a little bit more richer because the computer dumps more fuel because it was made for a dohc
Old Apr 23, 2004 | 04:16 PM
Gant's Avatar
Default Re: can i use a 87 pg7 ecu? (CivicHatchSOHC)
ok 2 ppl say no, one guy says i can use it guess i'll find out when i plug it in
im dropping a single cam zc in my hatch and i'll guess i'll see if it will work when i plug it in, my hatch is a std so its got dual point im gonna try and use it when i drop the zc motor in
Old Apr 23, 2004 | 06:03 PM
EG8R's Avatar
No you can't 87 uses vaccum advanced timing....
If you need a 88-89 PG7 I have one for sale....
edit: I put can instead of can't
Modified by skelly ed666 at 11:35 PM 4/23/2004
Old Apr 23, 2004 | 06:31 PM
kylefakesi-r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0eKnEe &raquo;</TD></TR><TR><TD CLASS="quote">he was prolly using it on his brown top 87 d16a1 which ppl like to call zc's. Cant use it because on the 87's the distributors use that vacume advance shyte.</TD></TR></TABLE>
<FONT SIZE="4">right</FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHatchSOHC &raquo;</TD></TR><TR><TD CLASS="quote">if you have 88-91 civic with a multiport conversion or if its an Si you can use it...they rev up to 7600. it wont work with dualpoint. And it will make you run a little bit more richer because the computer dumps more fuel because it was made for a dohc</TD></TR></TABLE>
<FONT SIZE="4">wrong</FONT>
vacuum advance distributor ecus do NOT work on non-vacuum distributors.
Old Apr 23, 2004 | 08:54 PM
1point5CRX's Avatar
Default Re: can i use a 87 pg7 ecu? (kylefakesi-r)
&lt;~~~ running pg7 on sohc zc, didnt 'feel' too much diffrence over the pm6
Old Apr 27, 2004 | 09:02 PM
Project_ED8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylefakesi-r &raquo;</TD></TR><TR><TD CLASS="quote">
Quote, originally posted by t0eKnEe »
Quote, originally posted by CivicHatchSOHC »
vacuum advance distributor ecus do NOT work on non-vacuum distributors.</TD></TR></TABLE>
........can't use it chris! should of picked up that $20 PM6 ecu! lazy ***! LOL
jdm_dc_fan
Aug 25, 2007 09:12 AM
zc-monster
Jan 3, 2007 07:01 AM
bluesi00
Oct 18, 2005 04:42 PM
adnoh90Civic16
Sep 20, 2003 05:53 AM
2ndae86
Jul 20, 2003 10:41 PM
