Oil...or lack thereof.
Old Apr 22, 2004 | 08:37 PM
Dyzee's Avatar
Default Oil...or lack thereof.
Hey guys,
Recently I did a D16Z6 swap into my car. Did a complete oil change etc etc.
Anyways, over the course of 4 weeks.. i have lost 2L..yes **2L*** of oil. I was using Castrol GTX 5W30 (dino..not synth).
So the first thing I did was check for leaks, my engine is spotless and not a hint of any oil leakage anywhere. Checked the ONLY 2 spots i park in during the day/night..NO signs of oil. I even put a large piece of clean cardboard under my car and let it sit for a few days...no leaks.
So since im not leaking, i must be BURNING oil right? There are also NO signs of burning. NO smoke anywhere, no wierd smells, no traces in exhaust system or anything. Everything is top notch.
I checked my rad(fearing its getting into the coolant), did a flush and it was clean as hell. No problems there.
Comp test shows ~180 across the board.
Leakdown test shows 3-4% across the board.
So I ask everyone, where is my oil going? And what can I do to prevent this?
Old Apr 22, 2004 | 08:44 PM
Kangaroo_Boy's Avatar
Default Re: Oil...or lack thereof. (Dyzee)
damn, that is puzziling as hell. I honestly have no idea whatsoever. Good luck with that man, I hope you can find the problem
Old Apr 22, 2004 | 08:46 PM
sohcvtec1995's Avatar
Default Re: Oil...or lack thereof. (Kangaroo_Boy)
got me?
Old Apr 22, 2004 | 08:48 PM
Dyzee's Avatar
Anyone help a fellow Honda-tech'er out?
Old Apr 23, 2004 | 05:44 AM
boostin4drcivic's Avatar
Default Re: (Dyzee)
you must be burning it off man. my beater does that. it doesnt leak, but it damn sure burns it. mine is so bad tho that u can smell it and see it out the back window if i smash the gas hard. i knew the valve seals were bad when i bought it tho so no biggie. i just stay on top of it and refill when necessary.
Old Apr 23, 2004 | 05:48 AM
Happyman's Avatar
Default Re: (boostin4drcivic)
Take out your spark plugs...are they covered in oil?
Old Apr 23, 2004 | 06:01 AM
The King's Avatar
when vtec is engagaed alot of motors burn oil , hece saying vtec burns oil
Old Apr 23, 2004 | 04:48 PM
Dyzee's Avatar
Pulled my plugs out today. Everything seems to be fine. The motor is running just a bit rich but Im not worried about that.
The thing is. I've had a P06 (non-VTEC ecu) in my car for the past 3 weeks of me having my swap. Only the past week have i had a new P28 in my car. Meaning that i've only been able to play with VTEC for ab out a week. Theres no way im burning 2L of oil PER WEEK with VTEC.
Any other answers anyone?
94DB8
Feb 20, 2008 04:28 PM
TomTomTuning
Honda S2000
32
Jul 5, 2006 06:16 AM
bigslimdog
42
Mar 27, 2004 03:02 PM
diluted
Jan 17, 2004 07:54 PM
Seks
Nov 6, 2002 04:38 PM
