What damage can blowing your headgasket do?
Well i'm just contemplating my upcoming SOHC setup,
one of the parts I plan on doing to squeeze as much power out of it
as I can, for a small ammount of bread, is a thinner headgasket,
i'm hoping that, that, combined with a nice cam(which should enjoy the higher comp) will produce nice results.
Now I know the thinner gasket can only do so much so I want to go as thin as possible, like a y8 trimmed down to 1layer.
SO i'm a bit worried about the gasket not holding up,
what could happen if it blows, aside from having to swap in a new one?
thanks
thanks
a blown head gasket can leak coolant into your crankcase. when that **** gets on the bearings. it doesnt allow them to stay lubricated. so they get screwed up.
Can warp the head surface and the block surface, creating future leaks. Honestly, avoiding a blown HG is the best option. Having to put a new one is would be the least possible damage caused.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Mill the head and run a 2 layer, dont **** around with a 1 layer headgasket</TD></TR></TABLE>
good call
well you head gasket would be fucked up
good call
i've heard both good and bad about cometic gaskets. +0.3 in cr won't even do too much for you.
i maintain that if you want to bump compression, do so with pistons.
could you be more specific about your engine please?
well i'm thinking a jdm d15b vtec
dont even have the thing tho! still got my cx haha,
soon tho
but yeah you're probably right,
which is why I asked first of course.
I dont want to mill the head though, because I might go turbo later on
maybe i'll just try'n keep it simple,
stay low comp, throw a cam, boltons ,and leave it at that. should still be pretty fun.
I'm definetely down for the sohc feel.
soon tho
tampabud
Jun 19, 2016 10:07 AM
arielb1
14
Nov 3, 2004 07:14 AM
