need smaller sized O2 sensor
Old Apr 22, 2004 | 07:28 PM
tinkerbell's Avatar
Default need smaller sized O2 sensor
running JDM 4-1's and have welded two O2 bungs on the back of pipes 1 & 2 to run my PR3 ecu properly...
problem is that one of bungs positions was a little out and this put the O2 sensor (1 wire) very close to teh black and i can assume that thre was enough play in the header to allow the O2 sensor to touch the block adn eventually crack the O2 sensor case.
this is causeign a slight surgyness at very low levels of throttle input eg highway driving.
anyways, does anyone know of a differnt (smaller) O2 sensor i could use?
it needs to be the same thread size and about and about 1in shorter
TIA!
Old Apr 23, 2004 | 01:27 AM
tinkerbell's Avatar
Default Re: need smaller sized O2 sensor (tinkerbell)
anyone?
Old Apr 23, 2004 | 08:07 AM
ultimatehonda's Avatar
I believe they are all the same size. You just may have to reweld the o2 bung to give you more clearence.
Old Apr 24, 2004 | 02:07 AM
tinkerbell's Avatar
Default Re: need smaller sized O2 sensor (ultimatehonda)
nah, i have seen half sized ones, they must be aftermarket...
maybe i will ask a bosch dealer or something...
Old Apr 26, 2004 | 09:37 PM
tinkerbell's Avatar
a final bump for some help here...
nate10498
Jun 25, 2005 06:59 PM
creuger
Nov 15, 2002 07:11 PM
