no vtech and no codes. obd2 motor in obd0 car
Old Apr 22, 2004 | 06:03 PM
mobrep's Avatar
New User
Default no vtech and no codes. obd2 motor in obd0 car
Search ended with nothing.
No vtech and no codes. Checked oil level. It's good. Using an obd0 b16 ecu, obd0 injectors, dist., alt. and starter. Only one o2 with the second spliced into the first one. I'm kinda stumped. Any ideas?
Old Apr 22, 2004 | 06:39 PM
Origin's Avatar
Default Re: no vtech and no codes. obd2 motor in obd0 car (mobrep)
you did find a good ground right? just trying some of the simple things
Old Apr 22, 2004 | 06:50 PM
mobrep's Avatar
New User
Default Re: no vtech and no codes. obd2 motor in obd0 car (Origin)
yep. acually, there are 4grounds on the motor. all new.
btw. the rev limiter hits at 7500. but it will usually hit at 7k when in safe mode.
Old Jul 22, 2006 | 02:37 AM
OkkeN's Avatar
checked the vtec solenoid gasket?
hmm..it should throw codes, but it might be the vss as well..
delslow!
Sep 30, 2009 09:09 AM
B18c1vicrx
13
Dec 7, 2007 06:19 PM
hany
14
May 17, 2007 01:48 AM
piggypen
Oct 8, 2004 08:47 AM
