Type R into 93 gsr, need info please
Old Apr 22, 2004 | 05:54 PM
hatch4raceb16's Avatar
Default Type R into 93 gsr, need info please
Ok, here is what i have:
93 Integra GSR OBD1
Stock ecu with hondata
OBD 2 jdm B18c type r motor with all the parts on it (dist. alt. injectors)
type r harness
I dont have the old b17 motor , so i cant use the distrib, injectors, or alternator off of it.
What will i need to do to install this setup and run the obd2 motor in obd1. I was told I can cut the connectors off the stock harness and use teh obd2 connectors and wire them to the stock harness. Does this method work??
Thanks, please help
(gonna be doing this setup soon)
Old Apr 23, 2004 | 06:09 AM
red civic standard's Avatar
Default Re: Type R into 93 gsr, need info please (hatch4raceb16)
Yes this method will work. OBD2 electronics (injectors, distributor, alternator) can all be run OBD1.
You will use the stock 93 GSR wiring harness with a few modifications. You will cut off the injector plugs and distributor plugs from the 93 GSR harness and replace them with teh injector plugs and distributor plugs from the Type R wiring harness. That is it. All of the other plugs on the GSR harness will find their match on the new Type R motor.
I had to do the same thing to put a type R in my EF (which is running OBD1).
Old Apr 23, 2004 | 06:19 AM
Default Re: Type R into 93 gsr, need info please (red civic standard)
Ur gabes friend huh? Are u still mad hes selling, lol?? Thanks for the info, im just checkin.
Chris_'s Avatar
it should actually be good to go all you would need to do is swap the clips and plugs necessary for the obd2 components. if you have both harnesses it should be cake.
Old Apr 23, 2004 | 06:30 AM
Definitely still pissed at him. I have put hours and hours into this car and so has he. I guess he just wants a different project.
At least it's staying in Michigan. Let me know if you have any other questions as I know this car and motor pretty well.
757toad
Aug 14, 2008 03:24 AM
g356gear
Aug 11, 2008 09:41 PM
N hatch
20
Sep 6, 2004 11:55 AM
253EK
May 20, 2004 10:52 PM
eg_type_r93
Jul 1, 2003 08:56 PM
