what can lead to failed ring-lands?
Old Apr 22, 2004 | 04:30 PM
Rob Dizzle's Avatar
Default what can lead to failed ring-lands?
say its a new engine. is it lack of proper break in (bad a/f : ) or the tuner didnt get the tune as good as it should be?
or... ?
Old Apr 22, 2004 | 05:19 PM
L-B racing's Avatar
Default Re: what can lead to failed ring-lands? (Bob-DC2)
if the 2 small rings failed id say the best cause is the ring was too big for the hole. not enough clearence.
if the wavy ring failed most likely improper installation. as in the 2 ends were overlapping when installed.
never really seen a problem with them failing except when they sit for a while and freeze up.
Old Apr 22, 2004 | 05:21 PM
EKhatch's Avatar
Default Re: what can lead to failed ring-lands? (L-B racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-B racing &raquo;</TD></TR><TR><TD CLASS="quote">if the 2 small rings failed id say the best cause is the ring was too big for the hole. not enough clearence.
never really seen a problem with them failing except when they sit for a while and freeze up.</TD></TR></TABLE>
Are you referring to only the oil ring only in this statement?
Just a little confusing.
Thanks
Old Apr 23, 2004 | 05:12 AM
BryanPendleton's Avatar
Improperly gapped ring ends.
Old Apr 23, 2004 | 08:47 AM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">say its a new engine. </TD></TR></TABLE>
Stock cast pistons?
Old Apr 23, 2004 | 09:11 AM
Rob Dizzle's Avatar
Default Re: what can lead to failed ring-lands? (EKhatch)
yup yup
pornstar4777
Feb 14, 2008 12:47 PM
itrdave
May 1, 2007 10:44 AM
2k.civic.si
Jul 4, 2006 01:31 AM
rayglenn
Oct 12, 2005 10:29 PM
chinhead1228
Jun 17, 2003 09:38 PM
