HID installation help
Old Apr 22, 2004 | 02:55 PM
g5h22's Avatar
Default HID installation help
How do u install a H4 TL HID into a 94 accord? its already converted to H4. plz help. do i need any harness kit or something? thx. It is just like plug - ply?
Old Apr 22, 2004 | 06:45 PM
accordselux's Avatar
Me Gusta History
Default Re: HID installation help (g5h22)
Do you have a ballast kit and everything? Most HID conversions are like 1000 bucks if you get all the good stuff
Old Apr 22, 2004 | 08:23 PM
g5h22's Avatar
Default Re: HID installation help (accordselux)
yes. 2 ballast , 2 ignitor and the bulbs.
i'm not sure how to hook it up.
Old Apr 22, 2004 | 08:29 PM
-RedneckDave-'s Avatar
Working
You have to get the power supply from the stock headlight wires and then ground directly to the battery for the best ground cause you can fry an ignitor in a few seconds with a poor ground. How many wires are off of your ballast?
Old Apr 22, 2004 | 08:52 PM
g5h22's Avatar
Default Re: HID installation help (01accordv6)
looks like 2? one red and one white?
actually i bough this from this guy:
https://honda-tech.com/zerothread?id=834490
They kit will be here tomorrow so i want to prepare to install it
Thx a lot!
i still kinda confuse. could u be more detail plz. Thx
Old Apr 22, 2004 | 09:13 PM
Working
Well one off of the ballast (probably the red) is the power, and the other is probably the ground. Just cut the headlight plug and solder the power wires together and then solder an extension to the grounds to reach the battery and solder ring terminals on to the wires and ground to the battery. Let me know when you get them if you have any questions. I would also ask the guy who is selling them to you how he wired them up in his car, assuming he had them in his car I did not read the whole thread that was linked.
Old Apr 22, 2004 | 10:39 PM
g5h22's Avatar
Thx for reply !
well i AIM w/ the owner and i think i got it. lol
i am going to draw a diagram
Bye the way, he has a CIVIC and i drive a ACCORD. does it matter for the wiring ?it seems to be the same thing
Modified by g5h22 at 3:24 PM 4/23/2004
Old Apr 23, 2004 | 03:37 AM
boonacka's Avatar
an HID kit shouldn't require any cutting or soldering. everything is supposed to plug together.
Old Apr 23, 2004 | 06:28 AM
g5h22's Avatar
Default Re: HID installation help (boonacka)
This H4 kit is off a Civic, is it ok to install on a accord?
*i also use H4 bulbs and i do have red/black wires.
Old Apr 23, 2004 | 08:21 PM
g5h22's Avatar
I just installed my H4 and it looks good.
Old Apr 24, 2004 | 08:03 PM
sinister2c's Avatar
you will need a sheild under the bulb or else you will blind everyone and get pulled over. Something similar to the caspers electronics sheilds. You can make one out of sheet aluminum.
batto24GSR
Nov 29, 2012 11:23 PM
datssoled
Feb 19, 2007 12:13 AM
pinoyboy204
Nov 27, 2005 04:43 PM
UntouchableEX
May 29, 2005 04:36 PM
GhettoBrawls
Jun 27, 2003 10:52 PM
