i have a ? about wiring
Old Apr 22, 2004 | 02:19 PM
Audi A4's Avatar
Default i have a ? about wiring
heres my senario... i recently sold my system... worked find and all. i never took the wiring out just left it in just incase i got something else.. well ibought a amp and 2 10's.. so i go to hook them up and for some reason i wasnt working.. it was a loud constant thump from the speakers... not lioke usual.. its a off beat thump... so i take it out of my car and put it into a buddies car. it worked like a charm in his car. so then i though maybe my wiring is defective, so i took it out and installed a new wiring kit made by rockford... wel tried it again and it did the same thing in my car.. so i take it out and put it back in the other car.. works fine again... wtf is going on? could it be my cd palyer maybe? it used to wrok in my car but i doesnt anymore and i double checked the wiring and its all ran right... helllopp
Old Apr 22, 2004 | 03:19 PM
Ignitecivic's Avatar
Default Re: i have a ? about wiring (DRAG lll INTEGRA)
the amp is prolly defected. i had the same problem.
Old Apr 22, 2004 | 04:23 PM
GAtegs's Avatar
I'll take a look at it next time we meet up.
I doubt highly the amp is defective because then it would not play in another car.
Old Apr 22, 2004 | 04:50 PM
Audi A4's Avatar
Default Re: i have a ? about wiring (a98tegLS)
excato... it works in 2 diff other cars i tried out.. also the speakers worked in the other 2 cars.
Old Apr 23, 2004 | 08:01 AM
ubreak_ubuy's Avatar
double check ur rca cables. right and left is on correct channel and make sure it has no contact with each other or the chassis of the vehicle.....
Old Apr 23, 2004 | 12:09 PM
Audi A4's Avatar
Default Re: i have a ? about wiring (raceinspired)
yeah double check it all... im clueless
Old Apr 23, 2004 | 06:07 PM
jdmotorsports's Avatar
did you tape off the rca's or did you leave em out? sounds like bad pre-amp on your head. try this if possible. get a stereo>rca from radio shack(3$) and use a walkman to input directly into your amp. see if that works.
Old Apr 25, 2004 | 08:51 PM
andysdonuts's Avatar
this maybe completely off base but did you irun the ground and power wire to the amp in separate areas of the car. My buddy ran them next to each other and he had a sound like that because of the electrical interference from the power wire.
Old Apr 26, 2004 | 08:47 AM
Audi A4's Avatar
Default Re: i have a ? about wiring (andysdonuts)
na power is from the battery adn ground is of the chassis in the trunkl area.. but thx for the info.. i may go recheck the wiring again
Old Sep 20, 2004 | 11:47 PM
dylokjai's Avatar
i had the same [problem it was the rca output from the head unit(not the wire)...
Old Oct 29, 2004 | 08:17 PM
bdg4512's Avatar
Default Re: i have a ? about wiring (dylokjai)
I don't know if you ever fixed your problem or not, but your problem is that you had the positive and negative mixed up, ehich caused it to hit in reverse and sound like crap
Old Oct 29, 2004 | 08:28 PM
fcm's Avatar
fcm
Old Fart
Default Re: i have a ? about wiring (bdg4512)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdg4512 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if you ever fixed your problem or not, but your problem is that you had the positive and negative mixed up, ehich caused it to hit in reverse and sound like crap</TD></TR></TABLE> Brahahahahahahahahahaha that cracks me up <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andysdonuts &raquo;</TD></TR><TR><TD CLASS="quote">this maybe completely off base but did you irun the ground and power wire to the amp in separate areas of the car. My buddy ran them next to each other and he had a sound like that because of the electrical interference from the power wire.</TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ubreak_ubuy &raquo;</TD></TR><TR><TD CLASS="quote">double check ur rca cables. right and left is on correct channel and make sure it has no contact with each other or the chassis of the vehicle.....</TD></TR></TABLE> WHAT?, left and right? mixed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">heres my senario... i recently sold my system... worked find and all. i never took the wiring out just left it in just incase i got something else.. well ibought a amp and 2 10's.. so i go to hook them up and for some reason i wasnt working.. it was a loud constant thump from the speakers... not lioke usual.. its a off beat thump... so i take it out of my car and put it into a buddies car. it worked like a charm in his car. so then i though maybe my wiring is defective, so i took it out and installed a new wiring kit made by rockford... wel tried it again and it did the same thing in my car.. so i take it out and put it back in the other car.. works fine again... wtf is going on? could it be my cd palyer maybe? it used to wrok in my car but i doesnt anymore and i double checked the wiring and its all ran right... helllopp</TD></TR></TABLE> If you didn't tape off the RCAs you have probably damaged the preamp outputs, [RCA outs] if there is more then one set of outputs on the HU try another set. 94
Old Oct 31, 2004 | 12:48 PM
Butler10's Avatar
I went through the same problem when I replaced my system..I just had my RCAs switched up
Old Oct 31, 2004 | 01:36 PM
EBP_SI's Avatar
Default Re: i have a ? about wiring (Butler10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Butler10 &raquo;</TD></TR><TR><TD CLASS="quote">I went through the same problem when I replaced my system..I just had my RCAs switched up</TD></TR></TABLE>
The only thing thats going to happen if you switch the RCA's is your left and right will be backwards.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if you ever fixed your problem or not, but your problem is that you had the positive and negative mixed up, ehich caused it to hit in reverse and sound like crap</TD></TR></TABLE>
haha...kids these days...
patrickvertigo
Audio / Security / Video
Apr 11, 2011 06:37 AM
HONDRETTI
Sep 29, 2008 05:41 AM
92BluEH-3
19
Oct 28, 2005 01:50 PM
