Not as RICH anymore.
I have a Greddy Turbo kit, I've had it for about a month now and I just put on the type 31 intercooler. I notice that I'm not running as rich as I was before the intercooler. Before I was all Green on the A/F gauge. now I'm some green, some yellow. I'm running the same amount of boost that I was running before the intercooler, so I don't think it's due to more boost taking more fuel. Do you think I just need to get some injector cleaner or something? Or should I even be worrying about it? thanks in advance.
Trey
Trey
maybe you should do a wide band dyno run and check out your a/f ratio. then you can tell us a little about how much power those greddy turbo kits make. i am curious.
I know my story may sound kinda weird but here it is. I had a problem where I was reading rich all the way to the last green bar. Then I checked my valve lash and found out there was hardly any gap in my springs!!!. So I adjusted it and now It reads just right. The only time when it hits rich is when the turbo kicks in.
[Modified by yoshe95si, 12:17 AM 10/31/2001]
