Is This Dangerous?
Old Oct 30, 2001 | 09:41 PM
joeg26er's Avatar
Default Is This Dangerous?
My GSR sedan's radiator has many hairline cracks in the bronze/brown top plastic portion all around the perimeter.
It seeps/weeps coolant.
The radiator appears to be made of at least two pieces - a top plastic portion and an aluminum cooling body.
Will this self destruct catastrophically?
How much is a replacement radiator and is it easy to do?
Thanks
Old Oct 30, 2001 | 09:43 PM
JL 74's Avatar
Default Re: Is This Dangerous? (joeg26er)
change the radiator. When I had an Accord way back then, the radiator failed, the car overheated, damaged the engine, an absolute pain in the *** for something a couple of hundred of dollars could have fixed.
Old Oct 30, 2001 | 09:50 PM
Black96Cobra's Avatar
Short answer, yes. It will fail. Radiators are cheap (less than $200) and very easy to install. It is messy however, so wear old clothes. Took me about an hour start to finish to do mine.
Old Oct 30, 2001 | 09:51 PM
H23 Power's Avatar
Default Re: Is This Dangerous? (jl74)
replace it
i had a 94 prelude, had one small crack, i watch coolant ALL THE TIME, watched the temp ALL THE TIME, boom, one day i cracked the head...no warning, fix it
Old Oct 30, 2001 | 11:04 PM
SystemGSR's Avatar
Default Re: Is This Dangerous? (01GSR)
i had same kind of problem and i didnt find out about it until my engine compartment was dirty as hell from the water spraying around and when i was sitting in a drive threw and just happen to notice my **** was over heating luckily it was just bearly over the middle mark and i was able to shut it down.
Oh ya... i went with aftermarket radiator also, Fluidyne... great fit easy to install and works great.
[Modified by SystemGSR, 12:06 AM 10/31/2001]
sdinteg
Jun 1, 2010 11:26 PM
dwn2earth922
Sep 12, 2009 10:00 AM
halo2k7
17
Jul 23, 2008 09:57 PM
CTara12345
Sep 15, 2005 12:31 PM
EGh22aEG
Jan 9, 2002 06:37 PM
