can you run the wastegate with no spring????
i did this and my turbo spooled up for the first hour of driving. Now today when I drive the wastegate smacks open and releases before the turbo can spool.
could I have damaged a seal somehow?
the diaphram is fine.....should I have not run it without a spring in the wastegate?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yusoslo »</TD></TR><TR><TD CLASS="quote">should I have not run it without a spring in the wastegate?</TD></TR></TABLE>
Ummm...yeah it's there for a reason. The spring dictates when the WG opens without it the second any sort of pressure enters it will open.
PGT Driver
Apr 13, 2004 07:54 PM
. Along with my car
