Droning noise coming from tranny...
Old Apr 22, 2004 | 09:59 AM
RTW DC2R's Avatar
Default Droning noise coming from tranny...
I dont currently have any shifting problems or other tranny issues, but when Im sometimes coasting in gear or very lightly on the throttle, I can hear a slight droning noise that Im positive is from the trans. If I increase the throttle some, it will quickly go away. It kinda feels like it does it when there is not much load on the trans parts, like theres some slack or play in there. And as soon as I touch the gas hard enough to take the slack out, it goes away. Its been doing it for awhile now so Im not too concerned. But Im wondering if it might be bearings getting worn, or maybe gears or something. Ive changed trans fluids a few times but that doesnt seem to make a difference.
Old Apr 22, 2004 | 10:46 AM
bluemex's Avatar
Default Re: Droning noise coming from tranny... (RTW DC2)
I have a similar problem with the thanny too. It only makes nosies when i am in gear and coasting while off or light on the throttle.
Could it have anything to do with the clutch being worn out or loose?
Old Apr 22, 2004 | 10:48 AM
RTW DC2R's Avatar
Default Re: Droning noise coming from tranny... (bluemex)
Could be clutch I guess, mine is screwed up but its not worn out by any means, or maybe the lightweight flywheel "buzzing" or something.
Old Apr 22, 2004 | 11:01 AM
Opie's Avatar
Did I tell you mine makes the same noise the other day on the phone?
Old Apr 22, 2004 | 11:04 AM
RTW DC2R's Avatar
I believe you did. I never thought much about it til you said something so I figured Id get some opinions
Old Apr 22, 2004 | 11:23 AM
98cwitr's Avatar
Default Re: (RTW DC2)
mine does it too...i dont wory about it too much
Old Apr 22, 2004 | 11:27 AM
Dan GSR's Avatar
Default Re: (98cwitr)
maybe the dreaded input shaft bearing
i'll have to hear it myself
if you are coasting in gear, and then, push in the clutch, does it go away?
Old Apr 22, 2004 | 11:28 AM
RTW DC2R's Avatar
Dan Ill give it a try and let u know. It doesnt seem to be getting progressively worse though so thats why I never worried about it. Ill take you for a ride at the BBQ.
Old Apr 22, 2004 | 11:35 AM
Opie's Avatar
Default Re: (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">if you are coasting in gear, and then, push in the clutch, does it go away?</TD></TR></TABLE>
Yes for me. Its a churning noise that moves as fast as the car is revving and when I push in the clutch or move to neutral it stops.
Ill take you for a ride when I see ya for Korean BBQ
Dan GSR's Avatar
well if it is the input shaft bearing,
its best to fix it right away
as the damage may not be much now
but it WILL slowly ruin all the gears, and wind up costing a lot more than $70 in parts (which is what the bearings cost)
Old Apr 22, 2004 | 11:38 AM
Dan GSR's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">
Ill take you for a ride when I see ya for Korean BBQ </TD></TR></TABLE>
from your description is sounds like input shaft bearing
although its best to check other parts, which are easier to fix
wheel bearing
axles
throw out bearing
Old Apr 22, 2004 | 11:42 AM
RTW DC2R's Avatar
Ill take my chances and wait til I see you at the BBQ so you can see for yourself LOL Looks like Dan is gonna be busy haha
Old Apr 22, 2004 | 11:43 AM
Opie's Avatar
Well I can tell you that my driver side axel has crapped out on me because of 3 1/4 mile runs w/ my Drag radials about 3 weeks ago.
The car is beginning to make some noises that could either be a bearing or my Azenis showing signs or wear.
As for the TO bearing and input shaft bearing im not sure exactly what to check for to know if those are the culprit.
Old Apr 22, 2004 | 11:48 AM
.RJ's Avatar
.RJ
Default Re: (opie)
You guys cna actually hear anything over azenis road noise?
Old Apr 22, 2004 | 11:52 AM
Opie's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">You guys cna actually hear anything over azenis road noise? </TD></TR></TABLE>
I thought everyone was full of **** until about 2 weeks ago when the noises started and now its deafening
Old Apr 22, 2004 | 11:54 AM
.RJ's Avatar
.RJ
Default Re: (opie)
Sounds like you're driving over a freight train
Old Apr 22, 2004 | 11:55 AM
Dan GSR's Avatar
Default Re: (.RJ)
funny
i've gotten acutomed to the tire sound, and can't even hear it anymore
Old Apr 22, 2004 | 11:58 AM
RTW DC2R's Avatar
my tires (*** ho's) are completely bald, and Im on the stock exhaust, so I can hear everything now
corcoran_chris
Dec 11, 2008 10:07 AM
RTW DC2R
Oct 25, 2006 09:00 AM
RTW DC2R
Oct 8, 2006 08:10 PM
feelsfast
Jul 6, 2004 04:33 AM
Pinhead
Feb 4, 2002 12:37 PM
