k20a pistons in k20a3?
Old Apr 22, 2004 | 06:59 AM
jdmd's Avatar
Default k20a pistons in k20a3?
i have read a few things on the differences between the a3, a2, and a motors, but i was wondering if i would be able to put the dc5 R pistons from the k20a motor into my a3 block. just want a little extra hp until i'm ready for the swap.
and also just to double check, a header for a k20a will fit on the a3 correct, it's just the intake manifold side that doesnt work? please help me out, and i'm sorry if this has already been covered, i searched and couldnt find what i was looking for.
Old Apr 22, 2004 | 07:59 AM
that guy steveee's Avatar
Default Re: k20a pistons in k20a3? (theblackknight)
well first off, the bolt patterns for the exhaust and intake manifolds are the same for the A2/A3 and ITR A heads...its just the itr and type-s rsx downpipe angles are different than that of the si.....
yes you could put in the pistons...but our EP3/base rsx ecu's are not tuned for 12-1 compression! you would have to do the headswap with the rsx type-s ecu in place of the EP3/base rsx ecu....vtec in the base K20A3 is WAY different than in the original style K20A2/A
yes you could, but it wouldnt work that well due to the Air fuel ratio....and the high compression pistons wouldnt even reach their peak power potential due to our low redline and a/f mixture yada yada....do you get me?
Old Apr 22, 2004 | 09:35 PM
jdmd's Avatar
thank you for your reply. so basically, if i get the pistons, header, exhaust, etc. i will just have to run a different ecu. i dont want to swap the head out on this motor seeing as how i will be getting a k20a eventually. i just wanted to get a little bump in hp besides that which will come from the header/exhaust.
thanks again.
Old Apr 23, 2004 | 07:25 AM
stealthhatch's Avatar
Default Re: (theblackknight)
i dont think the a3 head will work for 12.0 comp. compared to the stock 9.8 your would need more then the ecu if you did run it i think there will be some vavle train problems
Old Apr 23, 2004 | 10:32 AM
jdmd's Avatar
yeah that makes sense too. damn this stupid a3 head, why did honda even bother with this thing. oh well, looks like i'll just save for the k20a instead.
thanks again.
HondaGSX
Aug 19, 2007 05:06 PM
Nixem
10
Mar 19, 2007 04:34 AM
tomlinson619
Apr 12, 2006 12:54 PM
HondaTek
Feb 11, 2005 09:08 PM
vimsen
Oct 26, 2003 03:02 PM
