stock or low comp. pistons. help?
ok...i am thinking of boosting pretty soon on my 99 si and i did a comp test (185 158 178 182) 2nd piston is pretty bad. should i get low comp pistons or should i jst get new si pistons? ne ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitvtecgetloud09 »</TD></TR><TR><TD CLASS="quote">ok...i am thinking of boosting pretty soon on my 99 si and i did a comp test (185 158 178 182) 2nd piston is pretty bad. should i get low comp pistons or should i jst get new si pistons? ne ideas?</TD></TR></TABLE>
uhhhh how are you sure it is the pistons?????
also don't screw around with cast stock **** throw them out and get some JE
well if your gonna put in some aftermarket pistons no point in keeping stock rods and when you boost you always want more. Thats why my car is in a million pieces right now
do a full rebuild w/ a fresh hone and you won't regret it.
well there is no point in just throwing pistons in there save your money and get new mains and rod bearings, new rods, pistons, rings, and a dingleberry honer, DIY man it isn't really that hard just make sure you plasiguage your bearings and you will be fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! »</TD></TR><TR><TD CLASS="quote">save up for some ctr pistons</TD></TR></TABLE>
I wouldn't recommend ctr pistons if your going to go FI
Stock B16 compression is enough dude why would you want to go higher???????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi »</TD></TR><TR><TD CLASS="quote">
Stock B16 compression is enough dude why would you want to go higher???????</TD></TR></TABLE>Seriously. Don't reply if you don't know what you're talking about.
