What mounts to use?
If i but any B series motor i will need the b series mount am i correct? Say i am doing a ls in a eg hatch i just need to get some ls mounts? please help new to the hatch game
I put a b18c1 in a del sol s(this should be the same for you) and I only needed the upper driverside mount from the integra (that is the big expensive one) and the AC mount for a del sol VTEC(around 120.00 from honda). you will also need the correct shift linkage and b series axles. The other mounts should come from your stock engine.
93delsolh22
Jul 17, 2011 09:16 AM
hotimportcrx
Nov 27, 2005 09:32 PM
ForceFed Coupe
Dec 13, 2003 04:19 PM
