Low idle, Low rpm when Decelerating
Old Apr 21, 2004 | 09:57 PM
all stock's Avatar
Default Low idle, Low rpm when Decelerating
Let me first start off by saying i've searched
cold start is fine,
inspected my plugs, they look fine
wires have 15k on them, oem
used carb cleaner
reset my ecu
3 month old dizzy (from brand new)
cleaned my iacv
adjusted the idle screw
coolant bypass on the IM
no vacuum leaks
Normally, when a car is warm it idles at 850 +/- 50, let say 900. I idle at 900. Normally, when you depress the clutch pedal, the tach needle drops from some point, lets say 3000 and then slows down to 1200 and slowly reaches your idle point.
My car drops from 3000, slows down to 1200 and slowly reaches 650 or so. (realize that the second mark is 500, not 0), then it goes back up.
Also, my idle drops 100rpms from normal or so during the day - even with the coolant bypass. I feel like I've lost power. Occasionally, my idle drops real low (600 or so) when rapidly engaging or disengaging the clutch - i.e. backing out, fast food, any lines.
Any ideas?
Edit - I guess you could call it bouncing, the tach needle bounces when it decelerates.
Modified by all stock at 6:52 PM 4/25/2004
Old Apr 21, 2004 | 10:04 PM
jiahanhao's Avatar
Default Re: Low idle, Low rpm when Decelerating (all stock)
university of civics and integras...
Old Apr 21, 2004 | 11:45 PM
strepto's Avatar
Where on the TB is the idle screw?
Old Apr 22, 2004 | 12:25 AM
all stock's Avatar
Default Re: Low idle, Low rpm when Decelerating (strepto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strepto &raquo;</TD></TR><TR><TD CLASS="quote">Where on the TB is the idle screw?</TD></TR></TABLE>
on the top,
if it's your first time adjusting the screw, u need to cut away the epoxy crap with a knife in order to insert the screwdriver.
Old Apr 22, 2004 | 07:56 AM
NWP4LIFE's Avatar
lot of type r do that, so do s2k's.
Old Apr 22, 2004 | 05:02 PM
all stock's Avatar
Default Re: Low idle, Low rpm when Decelerating (NWP4LIFE)
Are you sure? I have been unable to compare with my other friends yet, I have a FPR, but it's set relatively high (like, 48psi). I was going to check out the fuel/emissions, but I am pretty sure that's not the cause of it. I changed the filter out about 13k mi or a year ago.
i removed my charcoal canister.
it seems to do this a lot when it's warm out...ecu retarding the timing when it's warm?
I am pretty sure my car never did this beforehand...it only has 54k on it...
Old Apr 23, 2004 | 06:08 PM
all stock's Avatar
bumpity.
Old Apr 23, 2004 | 06:47 PM
vtec.dc2's Avatar
sounds normal.. does it still idle at 750-850rpm after it goes back up from 500-600rpm?
Old Apr 25, 2004 | 02:03 AM
all stock's Avatar
Default Re: Low idle, Low rpm when Decelerating (vtec.dc2)
idles at 750...it does it more often now, I think something is retarding the timing...
Old Apr 25, 2004 | 02:33 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock &raquo;</TD></TR><TR><TD CLASS="quote">I have a FPR, but it's set relatively high (like, 48psi). </TD></TR></TABLE>
We just put an FPR on my car, and the original unit seemed to be set for 52 psi (vacuum line off).
Not sure if this is going to completely cure your problem (might need to re-adjust your idle after resetting the fuel pressure. Stock is 47-54 psi (according to the manual). HTH
Old Apr 25, 2004 | 05:51 PM
all stock's Avatar
Default Re: Low idle, Low rpm when Decelerating (zygspeed)
sounds good.
I think my car may be pulling some timing since it's getting hotter nowadays also.
Old Apr 26, 2004 | 10:42 AM
PYMUGENITR's Avatar
every once in awhile my car has the exact same problem. It will bounce around from 1200 to 650 and occasionally die. Matter of fact it happened last weekend in downtown san francisco. I HATE IT!
Old May 10, 2004 | 08:14 PM
PYMUGENITR's Avatar
Default Re: (PYMUGENITR)
bump, anyone else have this?
Old May 10, 2004 | 08:34 PM
all stock's Avatar
i think it could be my alternator gettign lazy. the idle drops more and more when i use power windows. =/ at idle.
it's being a lil stubborn to start too...it's electrical, that's for sure.
Old May 10, 2004 | 09:02 PM
PYMUGENITR's Avatar
Default Re: (all stock)
im running a sound system that prolly isnt too healthy for it. You think it could be alternator?
We have the EXACT same problem here.
Old May 10, 2004 | 10:17 PM
TurblowR's Avatar
my car has been idleing at 750 for the past 3 years. does the same thing as your car. car runs strong. compression is 220 all across and leak down is like at 2% if i remember correctly (have to look at the invoice). dont worry about it.
Old May 11, 2004 | 02:49 AM
is3oo's Avatar
I had the same problem as you, but my tuner adjusted the fuel and cam gears and it went away.
Old May 11, 2004 | 10:19 AM
all stock's Avatar
i'm not running ANY aftermarket electrical system whatsoever. infact, i'm not even running a radio. my lights dim at night if i gas i below 4k rpm, but if i let go of the throtle in gear and engine brake, they light up again. i heard th is was normal, but regardless...
all stock's Avatar
try testing the alternator. oh, i have a grounding kit, so that won't fix the problem either.
Old May 11, 2004 | 10:20 AM
PYMUGENITR's Avatar
Default Re: (rowdy kimchee)
do you remember how he tuned it? Were you running lean and timing retarded?
Old May 11, 2004 | 02:20 PM
is3oo's Avatar
I was running rich and I believe my timing was retarded.
Old May 14, 2004 | 06:35 PM
all stock's Avatar
Default Re: (rowdy type R)
gunna try taking apart the FITV.
Old May 14, 2004 | 09:55 PM
all stock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock &raquo;</TD></TR><TR><TD CLASS="quote">gunna try taking apart the FITV.</TD></TR></TABLE>
k, i'm an idiot, ITRs don't have one.
Old May 14, 2004 | 09:58 PM
all stock's Avatar
news update: the needle dips up n down very slightly. i feel the motor "cough" often at idle.
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
90_Si
26
Jan 22, 2008 06:38 PM
efyou
Apr 18, 2007 06:00 PM
sykotic
Jul 1, 2006 08:55 AM
REDMAN1322
Sep 1, 2001 01:29 PM
