Will LS distributor work in GSR engine?
Old Oct 30, 2001 | 07:32 PM
FAST94GSR's Avatar
New User
Default Will LS distributor work in GSR engine?
anyone know?
Old Oct 30, 2001 | 08:06 PM
FSTASNTZ's Avatar
Default Re: Will LS distributor work in GSR engine? (FAST94GSR)
I know the LS Distributor has worked in many budget B16A swaps. I would think it would work in the GS-R. The legs do not all line up, you have to secure it by one leg and cut the rest off.
Over a year and no problems with the B16s yet...
Jason
Old Oct 31, 2001 | 07:46 AM
earl's Avatar
Default Re: Will LS distributor work in GSR engine? (FSTASNTZ)
I've done that. You're right, you must cut off 2 of the bolt holes to make it fit. The motor started and ran OK but I never really trusted the distributor again but it will work. Obviously, you don't cut off the bolt hole on top that allows you to adjust the timing.
Old Oct 31, 2001 | 09:36 AM
rainforest's Avatar
Default Re: Will LS distributor work in GSR engine? (earl)
yeah it works you cut off one of the legs on the dist so it doesent hit the vtec selonoid. and you just leave the other one on bolted. there you go.
HondaH22A
Sep 20, 2005 10:54 PM
PtPuff
Oct 4, 2004 11:43 PM
Racer338
Dec 11, 2003 11:16 AM
FAST94GSR
Oct 30, 2001 07:34 PM
