ITR Sway bar install but now i hear rattling noise.....
Old Oct 30, 2001 | 07:18 PM
SystemGSR's Avatar
Default ITR Sway bar install but now i hear rattling noise.....
Had the ITR rear sway bar installed today along with camber kit and tie rod ends and now i have this rattling noise. Looks like the sway bar is touching the exhuast. Anybody ever have this problem? What'd you do to fix?
Old Oct 30, 2001 | 07:48 PM
MintyDip's Avatar
Default Re: ITR Sway bar install but now i hear rattling noise..... (SystemGSR)
hmmm my guess is that it is installed upside down
it should look like this. notice where the bend is
Old Oct 30, 2001 | 08:30 PM
SystemGSR's Avatar
Default Re: ITR Sway bar install but now i hear rattling noise..... (MintyDip)
we'll i'm pretty sure it's not upside down but i'll check....
Old Oct 30, 2001 | 08:37 PM
junglistgsr's Avatar
everyone is pretty sure until they check...and then they do and..whoops its upside down, i've seen this happen like 20 times
Old Oct 30, 2001 | 09:02 PM
SystemGSR's Avatar
Default Re: ITR Sway bar install but now i hear rattling noise..... (junglistgsr)
lol, if this is true then i'm going to go to the shop and laugh at them they didnt know how to install the dam thing in the first place i had to print them out the bsq install manual I guess theirs a first time for everything.
I would have installed it my self but it was allready on the lift their and what the hell. I live in aparments and have no garage (really sucks i used to live in houses and this takes some getting used to) and well i hate working on my car in the parking lot. I'll check it out when i walk my Ex-GF out to her car.
Old Oct 30, 2001 | 10:13 PM
Legacy_CPA's Avatar
that's going to be my sway bar soon!!! muahaha
Old Oct 30, 2001 | 10:20 PM
2005 TSX's Avatar
Default ITR Sway bar.....
I am looking to install an ITR rear sway bar, but I am not sure where to begin. Right now my suspension on my car is completely stock except for front and rear upper ITR strut bars. Will I need better shocks if I install an ITR rear sway bar? Will I need to adjust my camber? Any help would be greatly appreciated before I jump into this project. Thanks.
Old Oct 30, 2001 | 10:35 PM
Isaac's Avatar
New User
Default Re: ITR Sway bar..... (2001 Integra GSR)
Get it!! I installed the ITR Swaybar with my stock suspension and felt virtually no body-roll after. A Very inexpensive upgrade (14mm-->22mm) that makes a dramatic difference. You'll be fine with the stock shocks. I didn't upgrade my spring/shocks until 3-4 months after my swaybar. The car will definitely be more neutral, rather than understeering. Ask anyone here, the best bang-for-your-buck mod!! If you have any questions with the installation e-mail me or IM me anytime. Good Luck!
Old Oct 30, 2001 | 10:47 PM
MintyDip's Avatar
Default Re: ITR Sway bar install but now i hear rattling noise..... ([626]99-GSR-69)
LOl hehehehe
yah
"SHOW ME THE MONEY!!!!!!!!!!!!!"
just so ppl know, I am planign to sell me ITR sway setup and get a comptech sway/tie combo
why u ask, its purrrrrrrrrrty
[Modified by MintyDip, 11:49 PM 10/30/2001]
Old Oct 30, 2001 | 10:50 PM
2005 TSX's Avatar
Default Re: ITR Sway bar..... (98 GS-R)
How hard of an install was it. Is it a basic take off and bolt on procedure?
Old Oct 30, 2001 | 10:56 PM
SystemGSR's Avatar
Yeop it's in backwards.... simple mistake, i'll take it back up their tomarrow. Hopfully nothing is broke. When i looked under their it wasnt hooked up to the LCA's anymore. The rubber things came out and now i have some endlinks with out the rubber peices... Hopfully those arnt broke?
Old Oct 30, 2001 | 11:40 PM
masterxfob's Avatar
Default Re: ITR Sway bar..... (SystemGSR)
how much did the whole kit cost? and how much for install? i'm also looking to get one.
Old Oct 30, 2001 | 11:43 PM
SystemGSR's Avatar
Default Re: ITR Sway bar..... (masterxfob)
ehh sway bar cost me like 60 bucks i think.. i'm not sure how much the usually run, the guy may have gave me a deal on it cant remember, i purchaced my tiens with then also so...
You will also need a Adapter kit to make it work. I got the BSQ one. just run a search on here for BSQ and you'll find the site.
As for install, i'm not sure also. I had a bunch of work done all at once.
Old Oct 30, 2001 | 11:56 PM
MintyDip's Avatar
its pretty simple
basically take off the bolts, drill 2 holes
and then bolt all the new stuff up
Old Oct 31, 2001 | 12:02 AM
masterxfob's Avatar
Default Re: ITR Sway bar..... (MintyDip)
doesn't the comptech kit cost like $350? is it really worth it?
Old Oct 31, 2001 | 12:11 AM
comptechgsr's Avatar
not worth it, when there is the stock itr bar...
also, the squeeking could be from a squirrel living in ur trunk
lol
Old Oct 31, 2001 | 04:36 AM
BSQ's Avatar
BSQ
Here's the short version:
1.) Remove stock rear swaybar
2.) Remove 2 tack-welded flange nuts
3.) Slightly enlarge 2 existing holes
4.) Install NEW TYPE-R REAR SWAYBAR
For the long version (i.e. step-by-step instructions with photos) go to: http://www.geocities.com/bretq/swaybar_install.html
Old Oct 31, 2001 | 08:21 AM
Isaac's Avatar
New User
Yup, Bret got it! That's an excellent way to install it. I have the Beaks kit which make installation a little harder, but I'd rather pay a little bit more to have the extra "added" protection. The BSQ kit that Bret sells has had no problems that I'm aware of either, so you really can't lose. Good Luck again!
Old Oct 31, 2001 | 08:42 AM
98SILVERGSR's Avatar
From: I want a 3some with Chasey Lane and Jenna Jameson, Canada
Make that 21...
Old Oct 31, 2001 | 08:44 AM
2005 TSX's Avatar
So, where can I find a new rear Type-R sway bar? Any recommendations? How much should I expect to pay?
Old Oct 31, 2001 | 09:05 AM
BSQ's Avatar
BSQ
Here are the Acura parts that will be need:
1.) 52300-ST7-Z01 rear swaybar ($58.30)
2.) 52315-ST7-Z01 swaybar bushing ($4.40) (2 needed)
3.) 52308-SS0-000 bushing bracket ($5.95) (2 needed)
4.) 52316-ST7-Z00 endlink bushing ($1.75) (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar ($4.90) (4 needed) – this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) ($2.45) (2 needed)
7.) 94050-08080 flange nut (8mm) ($0.50) (2 needed)
Note: all prices are from A&H Motorsports ( http://www.ahmotor.com ) (prices current as of 7/1/2001). Dealer prices tend to be somewhat higher than A&H, but it doesn't hurt to check prices.
Old Oct 31, 2001 | 01:22 PM
MattG's Avatar
New User
I am getting the Comptech swaybar/tiebar set. A swaybar is about 150 plus either of the tear out kits for $60 puts you around $200. A Comptech tie bar is just about $200 so I figured I would get everyting at once and not have to worry about rip out. If you want to save some money look for a junkyard sway bar. or order one from a dealer. Progress group was also recomended to me by some serious racers.
Old Oct 31, 2001 | 01:42 PM
ALF's Avatar
ALF
Default Re: ITR Sway bar install but now i hear rattling noise..... (MattG)
$108 for the swaybar and misc. required parts + $20 for BSQ kit equates to $128 (plus shipping from A&H). Not a bad deal IMO...just get everything from A&H and Bret and you should receive substantial savings.
Of course, if you want to go that extra mile and get a tie bar, the Comptech is not a bad choice for the money if it's $200.
Old Oct 31, 2001 | 01:56 PM
brwnrice's Avatar
Default Re: ITR Sway bar install but now i hear rattling noise..... (Dozed)
kinda off the topic but if you get the itr rear sway bar will you experience any understeer/oversteer? shouldn't you get the itr front sway bar too?
Old Oct 31, 2001 | 02:19 PM
mercury's Avatar
New User
Default Re: ITR Sway bar install but now i hear rattling noise..... (brwnrice)
You gotta try really hard to tune your FWD car to oversteer. With the ITR rear swaybar, you'll still have understeer, just less of it.
